On web client:
1. Share file from User A to User B
2. Login to User B
3. Try to move shared file from User B's root folder to any other folder
File moves quickly, like when moving User B's own file
Moving shared file generally takes ~3-4 seconds, but on averages takes 40 seconds
Operating system: Ubuntu 16.06 (EC2 - T2-xlarge)
Web server: apache
Database: mysql
PHP version: 5.6.30
ownCloud version: 10.0.3
Updated from an older ownCloud or fresh install: Update from 10.0.2
Where did you install ownCloud from: bitnami AWS AMI
http://text-share.com/view/b1db62a8
Are you using external storage, if yes which one: local/smb/sftp/...
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/...
