Hi all,
A quota I’m setting isn’t sticking.
- Set quota
- Wait
- Profit
Quota to stick
Quota resets to 20GB
Debian 8
Apache
MySQL
5.6?
10.0.9
Upgraded
Debian repo
See config here: https://pastebin.com/gm58rW3h
Enabled:
- activity: 2.3.7
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_pdfviewer: 0.9.0
- files_sharing: 0.10.1
- files_texteditor: 2.2.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 16.1.0
- market: 0.2.4
- notifications: 0.3.4
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
- user_external: 0.4
- user_ldap: 0.11.0
Disabled: - encryption
- external
No
No
LDAP
