'404 Not found' after successful setup
  1. Download
  2. Install from .rpm
  3. Launch.
Make it work…
Can’t reach login page, files not found
Operating system: CentOS Linux release 7.4.1708
Web server: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips mod_fcgid/2.3.9
Database: MariaDB 5.5.56
PHP version: 7.0.10
ownCloud version: (see ownCloud admin page) 10.0.4
not found
<?php
$CONFIG = array (
  'instanceid' => 'och7ojpvog5w',
  'debug' => true,
  'loglevel' => 0,
  'passwordsalt' => 'salt',
  'secret' => 'secret',
  'trusted_domains' =>
  array (
    0 => 'my_IP',
  'datadirectory' => '/mnt/docs',
  'overwrite.cli.url' => 'http://my_IP/owncloud',
  'dbtype' => 'mysql',
  'version' => '10.0.4.4',
  'dbname' => 'owncloud_docs',
  'dbhost' => 'localhost',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'oc_user',
  'dbpassword' => 'mypass',
  'logtimezone' => 'UTC',
  'installed' => true,
php: command not found
Are you using external storage, if yes which one: NFS
Are you using encryption: No
Browser: Firefox 52.7.3
Operating system: Debian 9
[Fri Apr 13 09:32:20.933546 2018] [mpm_prefork:notice] [pid 6436] AH00170: caught SIGWINCH, shutting down gracefully
[Fri Apr 13 09:32:22.088014 2018] [core:notice] [pid 18231] SELinux policy enabled; httpd running as context system_u:system_r:httpd_t:s0
[Fri Apr 13 09:32:22.089805 2018] [suexec:notice] [pid 18231] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Apr 13 09:32:22.127138 2018] [alias:warn] [pid 18231] AH00671: The Alias directive in /etc/httpd/conf.d/manual.conf at line 5 will probably never match because it overlaps an earlier Alias.
[Fri Apr 13 09:32:22.127386 2018] [alias:warn] [pid 18231] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 18 will probably never match because it overlaps an earlier Alias.
[Fri Apr 13 09:32:22.127406 2018] [alias:warn] [pid 18231] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 19 will probably never match because it overlaps an earlier Alias.
[Fri Apr 13 09:32:22.127414 2018] [alias:warn] [pid 18231] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 20 will probably never match because it overlaps an earlier Alias.
[Fri Apr 13 09:32:22.127422 2018] [alias:warn] [pid 18231] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 21 will probably never match because it overlaps an earlier Alias.
[Fri Apr 13 09:32:22.127441 2018] [alias:warn] [pid 18231] AH00671: The Alias directive in /etc/httpd/conf.d/welcome.conf at line 22 will probably never match because it overlaps an earlier Alias.
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using localhost.localdomain. Set the 'ServerName' directive globally to suppress this message
[Fri Apr 13 09:32:22.128456 2018] [auth_digest:notice] [pid 18231] AH01757: generating secret for digest authentication ...
[Fri Apr 13 09:32:22.129874 2018] [lbmethod_heartbeat:notice] [pid 18231] AH02282: No slotmem from mod_heartmonitor
[Fri Apr 13 09:32:22.139134 2018] [mpm_prefork:notice] [pid 18231] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips mod_fcgid/2.3.9 configured -- resuming normal operations
[Fri Apr 13 09:32:22.139186 2018] [core:notice] [pid 18231] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
empty
Additionally, I tried to reach login page with SELinux in permissive mode. Doesn’t help.
I think you’re missing the Apache configuration shown e.g. here:
