Please forgive me as I am a first timer here.
The problem I am facing is “sometimes” owncloud give me a 404 error while accessing with hostname but it works with the ipAddress/owncloud URL. What could be the potential problem?
/etc/apache2/sites-available/owncloud.conf from IP address.
<VirtualHost *:80>
ServerAdmin admin
DocumentRoot /var/www/html/owncloud/
ServerName ***.com
ServerAlias www.***.com
Alias /owncloud "/var/www/html/owncloud/"
<Directory /var/www/html/owncloud/>
Options +FollowSymlinks
AllowOverride All
Require all granted
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /var/www/html/owncloud
SetEnv HTTP_HOME /var/www/html/owncloud
</Directory>
</VirtualHost>
following is my /var/www/html/owncloud/config/config.php file.
<?php
$CONFIG = array (
'instanceid' => '***',
'passwordsalt' => '***/',
'secret' => '***',
'trusted_domains' =>
array (
0=>'www.***.com',
1=>'http://www.***.com',
2=>'***.com',
3=>'178.62.*.*',
4=>'localhost',
'datadirectory' => '/var/www/html/owncloud/data',
'dbtype' => 'mysql',
'version' => '10.0.8.5',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'dbuser' => 'ownclouduser',
'dbpassword' => '****',
'logtimezone' => 'UTC',
'installed' => true,
The apache log has the following error. But this error should not cause the untrusted domain problem.
'/var/www/html/status.php' not found or unable to stat
'/var/www/html/remote.php' not found or unable to stat
