- start server
- login via website with my mainly used ownclouduser
- try Android owncloud Sync-App with same user
Cloud data should show normally
The website tells me “Access denied” (“Zugriff verboten”) and no further information.
The Android App says “authentication failed” (“Authentifizierung fehlgeschlagen”)
If I try another user or the admin user I can login to owncloud normally.
Raspbian GNU/Linux 9.11 (stretch)
nginx
mariadb
10.3.2
update
http://download.owncloud.org/download/repositories/production/Debian_9.0/
"system": {
"updatechecker": false,
"instanceid": "oc8qkd98rg6k",
"trusted_domains": [
"192.168.178.27",
"myserver.dyndns.org"
"overwrite.cli.url": "http:\/\/192.168.178.27",
"dbtype": "mysql",
"version": "10.3.2.2",
"dbname": "owncloud",
"dbhost": "127.0.0.1: 3306",
"dbtableprefix": "oc_",
"logtimezone": "Europe\/Berlin",
"logfile": "\/var\/log\/owncloud.log",
"loglevel": 2,
"installed": true,
"maintenance": false,
"theme": "",
"singleuser": false
Enabled:
- brute_force_protection: 1.0.1
- calendar: 1.6.3
- comments: 0.3.0
- configreport: 0.2.0
- contacts: 1.5.5
- dav: 0.5.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.1
- files_sharing: 0.12.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- gallery: 16.1.1
- market: 0.5.0
- notifications: 0.5.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
Disabled:
- encryption
- external
- updatenotification
- user_external
no
no
no
Firefox
Mageia Linux
2020/03/02 17:24:15 [notice] 30490#30490: signal process started
2020/03/02 22:07:57 [error] 30496#30496: *4071 open() "/var/www/owncloud/favicon.ico" failed (2: No such file or directory), client: 195.14.202.115, server: myserver.dyndns.org, request: "GET /favicon.ico HTTP/1.1", host: "myserver.dyndns.org"
{"reqId":"b3a1542f-6da3-4ba7-af6c-141afab97fa0","level":3,"time":"2020-03-02T22:05:39+01:00","remoteAddr":"195.14.202.115","user":"--","app":"webdav","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ownclouduser\/Rollenspiel\/Charaktere%20und%20Gruppenkram\/Numenera\/Musik\/Numeneramusik.txt","message":"Caused by: {\"Exception\":\"OC\\\\User\\\\LoginException\",\"Message\":\"Too many failed login attempts. Try again in 30 minutes.\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/brute_force_protection\\\/lib\\\/Hooks.php(95): OCA\\\\BruteForceProtection\\\\Throttle->applyBruteForcePolicy('ownclouduser', '195.14.202.115')\\n#1 \\\/var\\\/www\\\/owncloud\\\/apps\\\/brute_force_protection\\\/lib\\\/Hooks.php(63): OCA\\\\BruteForceProtection\\\\Hooks->preLoginCallback('ownclouduser')\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Hooks\\\/EmitterTrait.php(99): OCA\\\\BruteForceProtection\\\\Hooks->OCA\\\\BruteForceProtection\\\\{closure}('ownclouduser', '')\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Hooks\\\/PublicEmitter.php(33): OC\\\\Hooks\\\\BasicEmitter->emit('\\\\\\\\OC\\\\\\\\User', 'preLogin', Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/User\\\/Session.php(518): OC\\\\Hooks\\\\PublicEmitter->emit('\\\\\\\\OC\\\\\\\\User', 'preLogin', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/User\\\/Session.php(333): OC\\\\User\\\\Session->loginWithPassword(*** sensitive parameters replaced ***)\\n#6 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/User\\\/Session.php(362): OC\\\\User\\\\Session->login(*** sensitive parameters replaced ***)\\n#7 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Auth.php(131): OC\\\\User\\\\Session->logClientIn(*** sensitive parameters replaced ***)\\n#8 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Backend\\\/AbstractBasic.php(106): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth->validateUserPass(*** sensitive parameters replaced ***)\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Auth.php(239): Sabre\\\\DAV\\\\Auth\\\\Backend\\\\AbstractBasic->check(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#10 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Auth.php(156): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth->auth(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#11 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Plugin.php(193): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth->check(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#12 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Plugin.php(144): Sabre\\\\DAV\\\\Auth\\\\Plugin->check(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#13 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(96): Sabre\\\\DAV\\\\Auth\\\\Plugin->beforeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#14 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(448): Sabre\\\\DAV\\\\Server->emit('beforeMethod:PR...', Array)\\n#15 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(241): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#16 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(326): Sabre\\\\DAV\\\\Server->start()\\n#17 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#18 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#19 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/brute_force_protection\\\/lib\\\/Throttle.php\",\"Line\":101}"}
{"reqId":"cb6b02fa-2568-4ea8-a0a2-d64cb1deba7d","level":3,"time":"2020-03-02T22:05:39+01:00","remoteAddr":"195.14.202.115","user":"--","app":"webdav","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ownclouduser\/Rollenspiel\/Charaktere%20und%20Gruppenkram\/Rollenspiel%20D%26D%203_5\/Atuar%20Brightwood\/talente%20(2).txt","message":"Caused by: {\"Exception\":\"OC\\\\User\\\\LoginException\",\"Message\":\"Too many failed login attempts. Try again in 30 minutes.\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/brute_force_protection\\\/lib\\\/Hooks.php(95): OCA\\\\BruteForceProtection\\\\Throttle->applyBruteForcePolicy('ownclouduser', '195.14.202.115')\\n#1 \\\/var\\\/www\\\/owncloud\\\/apps\\\/brute_force_protection\\\/lib\\\/Hooks.php(63): OCA\\\\BruteForceProtection\\\\Hooks->preLoginCallback('ownclouduser')\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Hooks\\\/EmitterTrait.php(99): OCA\\\\BruteForceProtection\\\\Hooks->OCA\\\\BruteForceProtection\\\\{closure}('ownclouduser', '')\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Hooks\\\/PublicEmitter.php(33): OC\\\\Hooks\\\\BasicEmitter->emit('\\\\\\\\OC\\\\\\\\User', 'preLogin', Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/User\\\/Session.php(518): OC\\\\Hooks\\\\PublicEmitter->emit('\\\\\\\\OC\\\\\\\\User', 'preLogin', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/User\\\/Session.php(333): OC\\\\User\\\\Session->loginWithPassword(*** sensitive parameters replaced ***)\\n#6 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/User\\\/Session.php(362): OC\\\\User\\\\Session->login(*** sensitive parameters replaced ***)\\n#7 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Auth.php(131): OC\\\\User\\\\Session->logClientIn(*** sensitive parameters replaced ***)\\n#8 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Backend\\\/AbstractBasic.php(106): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth->validateUserPass(*** sensitive parameters replaced ***)\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Auth.php(239): Sabre\\\\DAV\\\\Auth\\\\Backend\\\\AbstractBasic->check(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#10 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Auth.php(156): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth->auth(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#11 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Plugin.php(193): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth->check(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#12 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Plugin.php(144): Sabre\\\\DAV\\\\Auth\\\\Plugin->check(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#13 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(96): Sabre\\\\DAV\\\\Auth\\\\Plugin->beforeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#14 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(448): Sabre\\\\DAV\\\\Server->emit('beforeMethod:PR...', Array)\\n#15 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(241): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#16 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(326): Sabre\\\\DAV\\\\Server->start()\\n#17 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#18 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#19 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/brute_force_protection\\\/lib\\\/Throttle.php\",\"Line\":101}"}
{"reqId":"beac70e6-dffc-41c8-9949-b76b6c458bdc","level":3,"time":"2020-03-02T22:05:40+01:00","remoteAddr":"195.14.202.115","user":"--","app":"webdav","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ownclouduser\/Rollenspiel\/Charaktere%20und%20Gruppenkram\/Rollenspiel%20D%26D%203_5\/Atuar%20Brightwood\/talente.txt","message":"Caused by: {\"Exception\":\"OC\\\\User\\\\LoginException\",\"Message\":\"Too many failed login attempts. Try again in 30 minutes.\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/brute_force_protection\\\/lib\\\/Hooks.php(95): OCA\\\\BruteForceProtection\\\\Throttle->applyBruteForcePolicy('ownclouduser', '195.14.202.115')\\n#1 \\\/var\\\/www\\\/owncloud\\\/apps\\\/brute_force_protection\\\/lib\\\/Hooks.php(63): OCA\\\\BruteForceProtection\\\\Hooks->preLoginCallback('ownclouduser')\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Hooks\\\/EmitterTrait.php(99): OCA\\\\BruteForceProtection\\\\Hooks->OCA\\\\BruteForceProtection\\\\{closure}('ownclouduser', '')\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Hooks\\\/PublicEmitter.php(33): OC\\\\Hooks\\\\BasicEmitter->emit('\\\\\\\\OC\\\\\\\\User', 'preLogin', Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/User\\\/Session.php(518): OC\\\\Hooks\\\\PublicEmitter->emit('\\\\\\\\OC\\\\\\\\User', 'preLogin', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/User\\\/Session.php(333): OC\\\\User\\\\Session->loginWithPassword(*** sensitive parameters replaced ***)\\n#6 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/User\\\/Session.php(362): OC\\\\User\\\\Session->login(*** sensitive parameters replaced ***)\\n#7 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Auth.php(131): OC\\\\User\\\\Session->logClientIn(*** sensitive parameters replaced ***)\\n#8 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Backend\\\/AbstractBasic.php(106): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth->validateUserPass(*** sensitive parameters replaced ***)\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Auth.php(239): Sabre\\\\DAV\\\\Auth\\\\Backend\\\\AbstractBasic->check(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#10 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Auth.php(156): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth->auth(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#11 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Plugin.php(193): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth->check(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#12 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Plugin.php(144): Sabre\\\\DAV\\\\Auth\\\\Plugin->check(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#13 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(96): Sabre\\\\DAV\\\\Auth\\\\Plugin->beforeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#14 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(448): Sabre\\\\DAV\\\\Server->emit('beforeMethod:PR...', Array)\\n#15 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(241): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#16 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(326): Sabre\\\\DAV\\\\Server->start()\\n#17 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#18 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#19 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/brute_force_protection\\\/lib\\\/Throttle.php\",\"Line\":101}"}
