We’ve had some mysterious folder deletions so I went to the activity plugin to see who was responsible but the last activity listed is from October 2018. I’ve checked the owncloud.log file and it runs up to today. Any thoughts on why that might be happening?
- Install activity plugin
- Check activity
- It only runs up to Oct 2018
Activity log should run to present day
Only date to 2018 is provided
Windows 10
“Apache/2.4.29 (Ubuntu)”
“10.4.0.4”,
updated
github file no longer exists
I pasted the config file contents but it went over the character limit for the post
