I have problem with Time add file in Cloud.
When I add file Time its 2 Day ago
You have aby idea about my problem ?
if you enter date
on command line do you have the current time, or also the wrong time on your system?
I dont have adress in hosting to comm line. Itd possible set date in setting cloud
I don't think you can set the time via Web UI, you need access to command line to restart the service.
Maybe the support of the hosting provider can help here?
