Admin personal settings are missing
Hi
I’am a new Owncloud user. I have installed Owncloud version 10.5 and everything is working fine (I can upload files, create users and so on)but I can’t see the personal settings on the admin page. I says that there is an internal server error. Can anybody help me here.
Best regards
Christian
centos 8
maria_db
Insert your ownCloud log [ADMINEDIT: removed] here
#### Browser log
c) …
You didn’t deliver any “real” information. I recommend starting with owncloud.log.
Hi Alfred
Here is the log…
Best regards
Christian
After a brief lookup in your log, more guessing:
The problem seems related to the language settings.
  • Which language do you have selected?
  • Is your PHP version matching ownclouds requirements?
Maybe it’s better if you work through the given Posting-template.
Hi again
  • I have set the language to danish. I have tried to change the language in Centos to english but it did not have any effect.
  • I have php version 7.4.13 installed
Thank you for helping me.
Best regards
Christian
I was referring to the language settings in owncloud. Have you selected danish there as well?
no. how do I set the language?
in my version I see the menu on the left in danish and folders are in english.
I think there was a problem with the Danish translations in 10.5. I suggest to use English for now. If it’s a fresh installation, you can wait until 10.6 is released.
The problem was with the translation itself, so it’s possible to change the translation, but I don’t know what was the offending one
As jvillafanez already wrote, there is an issue with Danish language in 10.5 (see Settings language to "Dansk" breaks settings page. · Issue #37799 · owncloud/core · GitHub).
So, in that release never use Danish as a language or apply the patch from the ticket above to your code base.
If you want to change the languages for any existing user from Danish to English, you can use the following command in your mariadb console:
UPDATE oc_preferences SET configvalue=‘en’ WHERE appid=‘core’ AND configkey=‘lang’ AND configvalue = ‘da’;
This will make the settings working again.
Thanks for the reply. I will focus on the language and try to change it to english.
Best regard
Christian
Hi cortho
Thank you. I will try to use the command in Mariadb.
Best regards
Christian
Hi Alfred
It was a language problem. I upgrade to version 10.6 and everything is working fine.
Best regards
Christian
