Good afternoon
I would very much like to get some help, but unfortunately I am NOT a computer specialists.
Most of the questions and replies I looked at in this forum, again “unfortunately”, are quite beyond me.
I do not really know, where to find most of the information you request, do all the highly technical
computer operations or run Linux commands.
So, maybe conclusion first: Do you have to be computer specialists with advanced technical knowledge
to use ownCloud? And are people like me (regular Joe) not supposed to go near it?
If so, I am really sorry to have asked.
The hosting service provider I use, does not offer support. Neither does the German company that created ownCloud,
or, in my case, the Japanese company supposed to be in charge of support here in Japan.
As a last resort I try this forum, but if my question (and me asking) is just too stupid,
please accept my apologies.
Situation:
About 3 weeks ago I installed the ownCloud server offered by the hosting service for my website.
The installation went without errors.
Later I installed the desktop client on 2 Windows (Japanese edition) 10 desktop machines (one a workstation) and designated a local folder to be synchronized, but EVERY TIME the latest version is supposed to be uploaded to the server, I get error messages like:
Server replied “403 Forbidden” from “PUT http://thoacu.com/ownCloud/remote.php/dav/files/nyuwa69/Suhara-NEW/SuharaBuch.odt” (skipped due to earlier error, trying again in 12 sec),Suhara-NEW/SuharaBuch.odt ,F:\ownCloud , ,Thomas Blasejewicz@thoacu.com,2022-02-26T15:17:34.914,Blacklisted
In the end ownCloud tells me it did/does not upload the latest file and I have to manually copy it to a USB stick.
This renders the whole idea of “file synchronization” rather useless.
I have been struggling with this for the last 3 weeks, several hours a day, but so far nothing I did had any effect.
Is there a way (preferably in plain English) to tackle this problem?
Here are a few pieced of information I found:
needsDbUpgrade
version 10.7.0.4
versionstring 10.7.0
Cron Last cron job execution: 12 days ago. Something seems wrong.
AJAX Execute one task with each page loaded
Webcron cron.php is registered at a webcron service to call cron.php every 15 minutes over http.
Cron Use system’s cron service to call the cron.php file every 15 minutes.
Does this point to any possible problem? Under “Cron” it says “something seems wrong”.
If there is a trick to get this thing running, I would be very grateful.
Thank you
Nyuwa
