Hi, i installed the latest Appliance Installation with OwnCloud 10.2.1. Is there a plan to get an updated 10.3 version for that environment ?
Regards Holger
Hi, Yes. There is a plan. The release should be soon.
Hi Dmitry,
i just follow this guideline: https://doc.owncloud.org/server/10.3/admin_manual/maintenance/manual_upgrade.html
and it works for me.
Thx
Holger
HOW?! Did you exec into the container, and run the update inside the container?
This seems totally inconceivable to me and I would strongly advise anybody running the appliance against doing this.
Just wait until the new appliance version is released.
I agree with @eneubauer completely.
Here the 2 different sections:
You followed the manual upgrade of the ownCloud server.
The appliance has it’s own upgrade section. This is no coincidence nor is this purely cosmetic. The appliance works differently than a normal ownCloud server.
Be aware, that any changes done to the appliance that are not documented by ownCloud are done on your own risk.
ok. i understood. Now i go back to the Snapshot taken before the update and wait for the appliance ones.
Thank you very much !
