Good morning
I have been using owncloud for about two months now. I was very difficult to get started, but now it seems to running.
On two Windows 10 machine I installed the desktop client, which automatically starts at power up as specified in settings.
On a Linux (Mint Debian Edition 5) machine however, the desktop client is an “AppImage” and although it is too set to “autostart”, it never does that. If I want to use it, I have to start it manually each time I power up the PC. The same problem has been reported by others on the net AND in connection with nextcloud.
So, the simple question is: IS there a way to get autostart to work on a Linux machine?
Thank you.
ownCloud version:
Client version:
OS language:
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also Redirect Notice ) -
Web server error log:
