- Block Storage not recognised when logging into Owncloud app
- Block storage visible in Vultr server dashboard
- Developer waiting to transfer files for storage
Tell us what should happen - Block Storage should be available and visible in Owncloud
Tell us what happens instead - Block Storage not available, although it appears in Vultr dash
Operating system: Loaded Owncloud app directly on to Vultr instance as their instructions
Web server: Vultr Instance
Database: ?
PHP version: ?
(https://owncloud.org) 10.2.1 (stable)
**Updated from an older ownCloud or fresh install: fresh install, 2 weeks ago
**Where did you install ownCloud from: via Vultr dashboard on setup
**Signing status (ownCloud 9.0 and above): 10.2.1
**The content of config/config.php: “file not found”
If done manually then it is critical for your own privacy to diligently
**List of activated apps: none, other than storage of files
**Are you using external storage, if yes which one: Vultr Block Storage
Are you using encryption: only Owncloud settings
**Are you using an external user-backend, if yes which one: No
File not found
The specified document has not been found on the server.
On update page, cURL error 60: SSL certificate problem: self signed certificate
Browser: Firefox
Operating system: Win 10
Sorry, I am not a technical person, if your system requires this level to operate it then the text on the Owncloud website should be revised to reflect the technical requirement. This is a simple attachment issue - either the S3 is attached and Owncloud can see it, or its not. Vultr says its attached, so it would seem there is an issue in what Owncloud can see. Hope someone can help.
