Hi
I installed owncloud on a fresh Opensuse Leap 15 installation. PHP is version 7 and Apache is 2.4.33.
I followed the installation steps.
If I open http://localhost/owncloud/ , the browser asks me where I want to save index.php.
I am not an apache specialist, but I think it is Apache related. Does anybody have an idea?
Joachim
