User’s files or files cannot be shared to users, they can be shared with groups,
However,system’s can do that ,and no problem to operate on the web
What is the problem ,thank you.
Operating system:debain
ownCloud version:last
Client version:2.11.1
Operating system: win10
OS language:
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also Redirect Notice ) -
Web server error log:
Server logfile: ownCloud log (data/owncloud.log):none
