how to create logs daily basis
What a question! Please be more precise.
in owncloud there is logs is bundle, how i can make logs is daily basis ?
there is possible logs customize ?
Have a look at the following configuration parameters and give them a go in a test environment:
https://doc.owncloud.com/server/admin_manual/configuration/server/config_sample_php_parameters.html#logging
Depending on your exact logging configuration you’d have adjust your logrotate configuration for daily logs. I’d recommend to read the manual pages for logrotate.
