Changing owncloud location issue
i have fresh installed owncloud and its located at /var/www/owncloud, and i want to relocate the owncloud location to /mnt/owncloud, and i did the following, after that when i access to https://192.168.1.99/owncloud - its show i do not have permission, but i already “chown -R apache: /mnt/owncloud” , but no luck, any help would be appreicated
  1. sudo rsync -av /var/www/owncloud/data/ ~/owncloud-data-bak
  2. sudo mv /var/www/owncloud/data /mnt/owncloud/
  3. sudo nano /var/www/owncloud/config/config.php
‘datadirectory’ => ‘/mnt/owncloud/data’,
5. edit the /etc/httpd/conf.d/owncloud.conf -
Alias /owncloud "/mnt/owncloud/"
<Directory /mnt/owncloud/>
  Options +FollowSymlinks
  AllowOverride All
 <IfModule mod_dav.c>
  Dav off
 </IfModule>
 SetEnv HOME /mnt/owncloud
 SetEnv HTTP_HOME /mnt/owncloud
</Directory>
### Actual behaviour
### Server configuration
**Operating system**:
CentOS Stream9
**Web server:**
httpd
**Database:**
MySQL version 8.0.30
**PHP version:**
PHP 7.4.33
10.10.0.3
fresh install
https://download.owncloud.com/server/stable/owncloud-complete-latest.tar.bz2
**List of activated apps:**
SELECT * FROM oc_appconfig WHERE appid = ‘user_ldap’;
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
c) …
That’s not the full story. You need to run some DB migration as well.
so i need the following in the SQL right ?
Fix Hard-coded Database Path Variables
Update the oc_storages Table
Update the oc_accounts Table
###Update the oc_jobs Table
Fix the Application Settings
