Hi all,
I'm sorry if this thread is in the wrong catagorie.
I wanted to use a anti-virus program in owncloud 9.1.0 so I was looking into clamAV. I do this in Linux Mint 18.
First you must install it and then activate in owncloud but you are not done yet. As it stands today you have installed
clamav and clamav-daemon
but when you try to use
freshclam
you get errors. After some research I found out that
clamav-daemon
isn't running! So no file are scanned during upload.
To activate it do
sudo service clamav-daemon start
and let it run.
Now you have clamav active and you can check it with
netstat -a | grep clam
