- username can login on web portal
- testpilot client connects to server with same credentials
- username can connect and upload/download files on web portal, server works perfectly fine: OK
- desktop client cannot connect: KO
error with connection closed, cannot login
=> error does not happens with testpilot 2.5.1
Also, client desktop testpilot 2.5.1 on stable channel proposes to update to 2.5.2 but only 2.5.4 is available.
- install testpilot desktop client 2.5.4 or 2.6.0alpha1 on Windows 10 Pro x64
- enter server address, username and password
- click connect
host: Ubuntu 16.04 AWS
docker container: Ubuntu 18.04 + ownlcloud 10.0.10 or 10.2.0 (tried both)
host: nginx/1.10.3 (Ubuntu) + php 7.2-FPM
docker container: nginx/1.14.0 (Ubuntu)
docker container MariaDB
docker container Redis
host: php 7.2-FPM
docker container: php 7.2-FPM + OPcache + APCu
ownCloud version:
10.0.10
10.2.0
docker volume (local fs)
Client version:
testpilot edition 2.5.1: ok
testpilot edition 2.5.4: ko
testpilot edition 2.6.0alpha1: ko
Windows 10 Pro x64 (2 different machines)
OS language:
english
Installation path of client:
C:\Program Files(x86)
/data/website.com/logs/nginx.access.log
when it doesn't work:
client.ip.0.0 - - [04/Jun/2019:18:50:25 -0400] "PROPFIND /remote.php/dav/files/username/ HTTP/1.1" 401 460 349 0.023 0.023 "-" "Mozilla/5.0 (Windows) mirall/2.6.0alpha1 (build 11574) (testpilotcloud)" "-"
client.ip.0.0 - username [04/Jun/2019:18:50:31 -0400] "GET /status.php HTTP/1.1" 200 156 566 0.016 0.016 "-" "Mozilla/5.0 (Windows) mirall/2.6.0alpha1 (build 11574) (testpilotcloud)" "-"
client.ip.0.0 - username [04/Jun/2019:18:50:31 -0400] "PROPFIND /remote.php/dav/files/username/ HTTP/1.1" 400 0 657 0.108 - "-" "Mozilla/5.0 (Windows) mirall/2.6.0alpha1 (build 11574) (testpilotcloud)" "-"
when it works:
client.ip.0.0 - - [04/Jun/2019:20:54:52 -0400] "PROPFIND /remote.php/dav/files/username/ HTTP/2.0" 401 888 64 0.020 0.020 "-" "Mozilla/5.0 (Windows) mirall/2.5.1 (build 10808) (testpilotcloud)" "-"
client.ip.0.0 - username [04/Jun/2019:20:54:55 -0400] "GET /status.php HTTP/2.0" 200 681 309 0.015 0.015 "-" "Mozilla/5.0 (Windows) mirall/2.5.1 (build 10808) (testpilotcloud)" "-"
client.ip.0.0 - username [04/Jun/2019:20:54:55 -0400] "PROPFIND /remote.php/dav/files/username/ HTTP/2.0" 207 696 212 0.198 0.130 "-" "Mozilla/5.0 (Windows) mirall/2.5.1 (build 10808) (testpilotcloud)" "-"
Client logfile: testpilotcloud.exe does not accept parameters and does not generate logs
Web server error log: cf ### Logs
Server logfile: ownCloud log (data/owncloud.log): irrelevant, does not get appended until the client is connected
Owncloud is hosted in a docker container, called audioscavenger/owncloud-lemp:latest and is a fork of your own dockerfile, but with nginx instead of apache. I didn’t change anything relevant and the server works fine.
I thought I made some mistakes on the server side and updated the container from owncloud 10.0.10 to 10.2.0 but same issue.
The issue is the testpilot desktop client on windows, version 2.6.0alpha1 and 2.5.4.
I solved my issue by downgrading the client to 2.5.1 but I hope it can help your development in some way!
