dt_64
September 2, 2019, 7:28am
#1
owncloud client v2.5.4 build 11415
client should just start up and operate
most times client crashes straight after boot (maybe 4 out of 5 cases), sometimes crashes a bit later
start client (fresh booted Win10)
client crahes
Win10 pro, latest patch level
nginx
mysql
ownCloud version:
owncloud 10.2
nextcloud 16.0.4
(connetions to both, works on other machines without issues, no change if connected to either one server only)
Client version:
Win10 pro latest patch level, domain, server-stored profile
OS language:
German/EnglishUK
Installation path of client:
C:\Program Files (x86)\ownCloud
crash reporter ID: e373cb3b-64d2-4dd2-b910-bdf8057377fc
Please use Gist (https://gist.github.com/ ) or a similar code paster for longer
logs.
Client logfile: Output of owncloud --logwindow
or owncloud --logfile log.txt
(On Windows using cmd.exe
, you might need to first cd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile )
Web server error log:
dt_64
September 4, 2019, 8:16am
#2
more occurences:
crash reporter IDs:
0067b566-ead0-4bf0-8315-d7a9f1279f2c
9edca2ba-a837-4df3-9c12-af80a861341f
log ends with:
09-04 07:47:31:347 [ info sync.csync.updater ]:
<= Closing walk for with read_from_db 0
09-04 07:47:31:347 [ info sync.csync.csync ]:
Update detection for remote replica took 0.251 seconds walking 202 files
09-04 07:47:31:347 [ info sync.engine ]:
#### Discovery end #################################################### 4902 ms
09-04 07:47:31:353 [ info sync.csync.csync ]:
Reconciliation for local replica took 0 seconds visiting 202 files.
Reconciliation for remote replica took 0 seconds visiting 202 files.
09-04 07:47:31:353 [ info sync.engine ]:
#### Reconcile end #################################################### 4908 ms
Permissions of the root folder: “DNVCKR”
09-04 07:47:31:390 [ info sync.engine ]:
#### Post-Reconcile end #################################################### 4946 ms
dt_64
September 5, 2019, 10:38am
#3
one more incident
crash reported ID 5bb3217c-9007-432b-bcdd-6aa1078d2cd3
09-05 12:33:45:201 [ warning sync.database.sql ]:
Sqlite prepare statement error: “disk I/O error” in “PRAGMA quick_check;”
Error preparing quick_check on database
09-05 12:33:45:202 [ critical sync.database.sql ]:
Consistency check failed, removing broken db “Y:/directoryname/._sync_4c454063a7b8.db”
09-05 12:33:45:206 [ info sync.database ]:
sqlite3 version “3.26.0”
sqlite3 locking_mode= “exclusive”
09-05 12:33:45:206 [ warning sync.database.sql ]:
Sqlite prepare statement error: “disk I/O error” in “PRAGMA journal_mode=WAL;”
09-05 12:33:45:206 [ fatal default ]:
ENFORCE: “allow_failure” in file C:\workspace\owncloudclient-2.5.4.11654\src\common\ownsql.cpp, line 269
tom42
September 20, 2019, 5:21pm
#4
personally i’m reporting a crash with an application always to a bugtracker (in this case this should be the one of the Desktop client) rather then to a user based support forums.
