- Install Owncloud 10.3.0 release
- Login to Web Interface
- Access Settings Page
- Review Security & Warnings at Top of Page
- See attached screenshot
Warnings should disappear after server-side configuration setup
The warnings do not disappear. Gives the appearance that something is not configured properly.
CENTOS 6.10 [dedicated17] * [ v84.0.9]
Linux
MySQL
10.3.1
Fresh install
Softaculous App Installer
Nothing to paste here.
Here is the link to file https://www.dropbox.com/s/zlfrqsumqnu40de/config_report_20191118.json?dl=0
No
No
WebDAV
