I need step for configuration keycloak into ownload.
I have this error
Error in OpenIdConnect:The provider authorization_endpoint could not be fetched. Make sure your provider has a well known configuration available.
Following the recommendations from keycloak, you should have your own realm there (check some official keycloak guide).
Assuming your realm is ownCloudCloak
, the target “provider-url” you need to setup in ownCloud’s config.php file is http://my.keycloak.server/realms/ownCloudCloak
(adjust protocol and server as needed)
Work but have this message
Error in OpenIdConnect:PKCE code verifier not specified
