Hello, I’m wondering if owncloud supports loading from an existing S3 bucket, or does it have to create a new bucket? I tried to mount an existing bucket and got failures below.
- Installed Marketplace
- Went to settings / storage and put in the credentials and an existing bucket name for S3
The S3 bucket should be loaded directly.
Loading the external S3 bucket failed, with logs saying
{\"Exception\":\"Exception\",\"Message\":\"Creation of bucket failed. Error executing \\\"CreateBucket\\\"
Operating system: ubuntu 20.04
Database: mariadb:10.5
ownCloud version: owncloud version 10.8
Where did you install ownCloud from: Docker compose from https://raw.githubusercontent.com/owncloud/docs/master/modules/admin_manual/examples/installation/docker/docker-compose.yml
Are you using external storage, if yes which one: Trying to but not working
Are you using encryption: no
Browser: Chrome
Operating system: Mac OS Big Sur
