Tell us what should happen: context menu for sharing links appears by klicking on folders.
Tell us what happens instead: context menu appears as "owncloud" without any function. I went back to 2.3.4
- update from client 2.3.4 to 2.4
Client version: 2.4
Operating system: mac OS 10.10 and 10.11
OS language: de
Installation path of client: applications
logs.
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile )Web server error log:
