sg72
August 7, 2020, 7:52am
#1
I have a problem with Owncloud Version 2.6.3 (build 13765)
When I open owncloud ‘settings’ the page opens fine but when I close it owncloud crashes !!
In the console, they are this message
|erreur|09:28:29.228007+0200|tccd|Prompting policy for hardened runtime; service: kTCCServiceAppleEvents requires entitlement com.apple.security.automation.apple-events but it is missing for RESP:{ID: owncloud_crash_reporter, PID[1017], auid: 501, euid: 501, responsible path: '/Applications/owncloud.app/Contents/MacOS/owncloud', binary path: '/Applications/owncloud.app/Contents/MacOS/owncloud_crash_reporter'}, ACC:{ID: owncloud_crash_reporter, PID[1017], auid: 501, euid: 501, binary path: '/Applications/owncloud.app/Contents/MacOS/owncloud_crash_reporter'}, REQ:{ID: com.apple.appleeventsd, PID[316], auid: 55, euid: 55, binary path: '/System/Library/CoreServices/appleeventsd'}|
|erreur|09:28:29.252974+0200|tccd|{ID: owncloud_crash_reporter, PID[1017], auid: 501, euid: 501, binary path: '/Applications/owncloud.app/Contents/MacOS/owncloud_crash_reporter'} attempted to call TCCAccessRequest without the com.apple.private.tcc.manager.check-by-audit-token entitlement|
|erreur|09:28:29.257373+0200|tccd|{ID: owncloud_crash_reporter, PID[1017], auid: 501, euid: 501, binary path: '/Applications/owncloud.app/Contents/MacOS/owncloud_crash_reporter'} attempted to call TCCAccessRequest without the com.apple.private.tcc.manager.check-by-audit-token entitlement|
|panne|09:28:40.340080+0200|apsd|Peer connection [pid=451] lacks APSConnectionInitiateEntitlement|
|erreur|09:28:40.340173+0200|amsaccountsd|Interrupted connection to service com.apple.apsd|
Did you send the crash report? Could you post the crash ID that is shown after submission?
sg72
August 7, 2020, 8:09am
#3
Yes I send the crash report
Where is the crash ID ?
sg72
August 7, 2020, 8:18am
#4
When open owncloud they are
|erreur|10:16:28.377078+0200|diagnostics_agent|Invalid receipt [0 bytes]|
|erreur|10:16:28.723472+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:28.827908+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:28.830442+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:28.906893+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:28.955971+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.044231+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.087933+0200|runningboardd|RBSStateCapture remove item called for untracked item 284-132-490 (target:xpcservice<com.owncloud.desktopclient.FinderSyncExt(501)>)|
|erreur|10:16:29.102943+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.420624+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.525938+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.529063+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.571016+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.651624+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.688643+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.727030+0200|pkd|[d <private>] [u A2DD5D61-DC0F-486E-8B96-C2706534472B] [<private>(<private>)] rejecting; Ignoring mis-configured plugin at [/Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex]: plug-ins outside containing apps must be protected by SIP.|
|erreur|10:16:29.904020+0200|FinderSyncExt|Bootstrapping; external subsystem UIKit_PKSubsystem refused setup|
|erreur|10:16:29.928106+0200|diagnostics_agent|Invalid receipt [0 bytes]|
|erreur|10:16:30.027399+0200|tccd|Prompting policy for hardened runtime; service: kTCCServiceAppleEvents requires entitlement com.apple.security.automation.apple-events but it is missing for ACC:{ID: com.owncloud.desktopclient.FinderSyncExt, PID[1247], auid: 501, euid: 501, binary path: '/Applications/owncloud.app/Contents/PlugIns/FinderSyncExt.appex/Contents/MacOS/FinderSyncExt'}, REQ:{ID: com.apple.appleeventsd, PID[316], auid: 55, euid: 55, binary path: '/System/Library/CoreServices/appleeventsd'}|
|erreur|10:16:30.031810+0200|tccd|{ID: com.owncloud.desktopclient.FinderSyncExt, PID[1247], auid: 501, euid: 501, binary path: '/Applications/owncloud.app/Contents/PlugIns/FinderSyncExt.appex/Contents/MacOS/FinderSyncExt'} attempted to call TCCAccessRequest without the com.apple.private.tcc.manager.check-by-audit-token entitlement|
|erreur|10:16:30.034491+0200|tccd|{ID: com.owncloud.desktopclient.FinderSyncExt, PID[1247], auid: 501, euid: 501, binary path: '/Applications/owncloud.app/Contents/PlugIns/FinderSyncExt.appex/Contents/MacOS/FinderSyncExt'} attempted to call TCCAccessRequest without the com.apple.private.tcc.manager.check-by-audit-token entitlement|
|erreur|10:16:30.515902+0200|tccd|{ID: com.apple.sandboxd, PID[154], auid: 0, euid: 0, binary path: '/usr/libexec/sandboxd'} attempted to call TCCAccessRequest without the com.apple.private.tcc.manager.check-by-audit-token entitlement|
|erreur|10:16:32.598942+0200|tccd|Prompting policy for hardened runtime; service: kTCCServiceAppleEvents requires entitlement com.apple.security.automation.apple-events but it is missing for ACC:{ID: com.owncloud.desktopclient, PID[1244], auid: 501, euid: 501, binary path: '/Applications/owncloud.app/Contents/MacOS/owncloud'}, REQ:{ID: com.apple.appleeventsd, PID[316], auid: 55, euid: 55, binary path: '/System/Library/CoreServices/appleeventsd'}|
|erreur|10:16:32.610517+0200|tccd|{ID: com.owncloud.desktopclient, PID[1244], auid: 501, euid: 501, binary path: '/Applications/owncloud.app/Contents/MacOS/owncloud'} attempted to call TCCAccessRequest without the com.apple.private.tcc.manager.check-by-audit-token entitlement|
|erreur|10:16:32.613025+0200|tccd|{ID: com.owncloud.desktopclient, PID[1244], auid: 501, euid: 501, binary path: '/Applications/owncloud.app/Contents/MacOS/owncloud'} attempted to call TCCAccessRequest without the com.apple.private.tcc.manager.check-by-audit-token entitlement|
|erreur|10:16:34.575110+0200|mdworker_shared|All kCFPreferencesCurrentUser domains in this process will be volatile, because homeDirPath starts with /var/empty|
sg72
August 7, 2020, 8:21am
#5
this id ? 599dbbee-9696-4f89-a25d-bf6d2017f637
