- Fresh manual installation of owncloud 10.4.0 on Debian host
- Add some files and install audioplayer plugin
- Try to scan the library. Only some of the files are visible. Re-scanning shows that there are some files, which might be added, but they aren’t
All of the files are added to library
Output of the scan command
su - www-data -s /bin/bash -c ‘/media/storage/owncloud/occ audioplayer:scan marcin -vv’
< audio files, which are present in the library >
Final audio files to be processed: 695
Total stream files: 0
Checking stream files to be skipped
Final stream files to be processed: 0
Start processing of audio files
< audio files which are not in the library >
Audios found: 26
Duplicates found: 0
Written to library: 26
Albums found: 8
Errors: 0
owncloud.log | tail
{"reqId":"XnOCmlDtPxgLVcE1RouC0wAAAAI","level":3,"time":"2020-03-19T14:32:59+00:00","remoteAddr":"192.168.2.121","user":"marcin","app":"no app in context","method":"GET","url":"\/owncloud\/index.php\/apps\/audioplayer\/scanforaudiofiles?requesttoken=MAABH1oOSDUVGyVpTTYyHwYoYjwvGjQ9cxNJNDgtLik%3D%3AZjhM3m1oTrN%2F8cWFpy7DiycUCVfspeiLTKqUMhRA%2BO0%3D","message":"DB error while building library: PDOException: SQLSTATE[22007]: Invalid datetime format: 1366 Incorrect string value: '\\xFE\\xFF' for column `owncloud`.`oc_audioplayer_albums`.`name` at row 1 in \/media\/storage\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php:117\nStack trace:\n#0 \/media\/storage\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php(117): PDOStatement->execute(Array)\n#1 \/media\/storage\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Statement.php(153): Doctrine\\DBAL\\Driver\\PDOStatement->execute(Array)\n#2 \/media\/storage\/owncloud\/apps-external\/audioplayer\/lib\/Controller\/DbController.php(304): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \/media\/storage\/owncloud\/apps-external\/audioplayer\/lib\/Controller\/ScannerController.php(305): OCA\\audioplayer\\Controller\\DbController->writeAlbumToDB('marcin', '\\xFE\\xFF', 0, NULL, 331)\n#4 \/media\/storage\/owncloud\/apps-external\/audioplayer\/lib\/Controller\/ScannerController.php(176): OCA\\audioplayer\\Controller\\ScannerController->scanAudio(Object(OC\\Files\\Node\\File), Object(getID3), Object(Symfony\\Component\\Console\\Output\\NullOutput))\n#5 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(153): OCA\\audioplayer\\Controller\\ScannerController->scanForAudios(NULL, Object(Symfony\\Component\\Console\\Output\\NullOutput), NULL)\n#6 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(85): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\audioplayer\\Controller\\ScannerController), 'scanForAudios')\n#7 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/App.php(100): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\audioplayer\\Controller\\ScannerController), 'scanForAudios')\n#8 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(47): OC\\AppFramework\\App::main('OCA\\\\audioplayer...', 'scanForAudios', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#9 \/media\/storage\/owncloud\/lib\/private\/Route\/Router.php(342): OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#10 \/media\/storage\/owncloud\/lib\/base.php(920): OC\\Route\\Router->match('\/apps\/audioplay...')\n#11 \/media\/storage\/owncloud\/index.php(54): OC::handleRequest()\n#12 {main}\n\nNext Doctrine\\DBAL\\Driver\\PDOException: SQLSTATE[22007]: Invalid datetime format: 1366 Incorrect string value: '\\xFE\\xFF' for column `owncloud`.`oc_audioplayer_albums`.`name` at row 1 in \/media\/storage\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php:119\nStack trace:\n#0 \/media\/storage\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Statement.php(153): Doctrine\\DBAL\\Driver\\PDOStatement->execute(Array)\n#1 \/media\/storage\/owncloud\/apps-external\/audioplayer\/lib\/Controller\/DbController.php(304): Doctrine\\DBAL\\Statement->execute(Array)\n#2 \/media\/storage\/owncloud\/apps-external\/audioplayer\/lib\/Controller\/ScannerController.php(305): OCA\\audioplayer\\Controller\\DbController->writeAlbumToDB('marcin', '\\xFE\\xFF', 0, NULL, 331)\n#3 \/media\/storage\/owncloud\/apps-external\/audioplayer\/lib\/Controller\/ScannerController.php(176): OCA\\audioplayer\\Controller\\ScannerController->scanAudio(Object(OC\\Files\\Node\\File), Object(getID3), Object(Symfony\\Component\\Console\\Output\\NullOutput))\n#4 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(153): OCA\\audioplayer\\Controller\\ScannerController->scanForAudios(NULL, Object(Symfony\\Component\\Console\\Output\\NullOutput), NULL)\n#5 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(85): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\audioplayer\\Controller\\ScannerController), 'scanForAudios')\n#6 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/App.php(100): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\audioplayer\\Controller\\ScannerController), 'scanForAudios')\n#7 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(47): OC\\AppFramework\\App::main('OCA\\\\audioplayer...', 'scanForAudios', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#8 \/media\/storage\/owncloud\/lib\/private\/Route\/Router.php(342): OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#9 \/media\/storage\/owncloud\/lib\/base.php(920): OC\\Route\\Router->match('\/apps\/audioplay...')\n#10 \/media\/storage\/owncloud\/index.php(54): OC::handleRequest()\n#11 {main}\n\nNext Doctrine\\DBAL\\Exception\\DriverException: An exception occurred while executing 'INSERT INTO `oc_audioplayer_albums` (`user_id`,`name`,`folder_id`) VALUES(?,?,?)' with params [\"marcin\", \"\\xfe\\xff\", 331]:\n\nSQLSTATE[22007]: Invalid datetime format: 1366 Incorrect string value: '\\xFE\\xFF' for column `owncloud`.`oc_audioplayer_albums`.`name` at row 1 in \/media\/storage\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php:106\nStack trace:\n#0 \/media\/storage\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php(169): Doctrine\\DBAL\\Driver\\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \/media\/storage\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php(145): Doctrine\\DBAL\\DBALException::wrapException(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'An exception oc...')\n#2 \/media\/storage\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Statement.php(162): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'INSERT INTO `oc...', Array)\n#3 \/media\/storage\/owncloud\/apps-external\/audioplayer\/lib\/Controller\/DbController.php(304): Doctrine\\DBAL\\Statement->execute(Array)\n#4 \/media\/storage\/owncloud\/apps-external\/audioplayer\/lib\/Controller\/ScannerController.php(305): OCA\\audioplayer\\Controller\\DbController->writeAlbumToDB('marcin', '\\xFE\\xFF', 0, NULL, 331)\n#5 \/media\/storage\/owncloud\/apps-external\/audioplayer\/lib\/Controller\/ScannerController.php(176): OCA\\audioplayer\\Controller\\ScannerController->scanAudio(Object(OC\\Files\\Node\\File), Object(getID3), Object(Symfony\\Component\\Console\\Output\\NullOutput))\n#6 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(153): OCA\\audioplayer\\Controller\\ScannerController->scanForAudios(NULL, Object(Symfony\\Component\\Console\\Output\\NullOutput), NULL)\n#7 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(85): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\audioplayer\\Controller\\ScannerController), 'scanForAudios')\n#8 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/App.php(100): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\audioplayer\\Controller\\ScannerController), 'scanForAudios')\n#9 \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(47): OC\\AppFramework\\App::main('OCA\\\\audioplayer...', 'scanForAudios', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#10 \/media\/storage\/owncloud\/lib\/private\/Route\/Router.php(342): OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#11 \/media\/storage\/owncloud\/lib\/base.php(920): OC\\Route\\Router->match('\/apps\/audioplay...')\n#12 \/media\/storage\/owncloud\/index.php(54): OC::handleRequest()\n#13 {main}"}
{"reqId":"XnOCmlDtPxgLVcE1RouC0wAAAAI","level":3,"time":"2020-03-19T14:33:00+00:00","remoteAddr":"192.168.2.121","user":"marcin","app":"PHP","method":"GET","url":"\/owncloud\/index.php\/apps\/audioplayer\/scanforaudiofiles?requesttoken=MAABH1oOSDUVGyVpTTYyHwYoYjwvGjQ9cxNJNDgtLik%3D%3AZjhM3m1oTrN%2F8cWFpy7DiycUCVfspeiLTKqUMhRA%2BO0%3D","message":"Cannot modify header information - headers already sent at \/media\/storage\/owncloud\/lib\/private\/AppFramework\/Http\/Output.php#62"}
cat /etc/debian_version
10.3
Server version: Apache/2.4.38 (Debian)
Server version: 10.3.22-MariaDB-0+deb10u1 Debian 10
PHP 7.3.11-1~deb10u1 (cli) (built: Oct 26 2019 14:14:18) ( NTS )
owncloud 10.4.0
Fresh install
Official website (owncloud-10.4.0.tar.bz2)
Enabled:
- audioplayer: 2.8.4
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.5.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.1
- files_sharing: 0.12.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- market: 0.5.0
- notifications: 0.5.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled: - encryption
- external
- user_external
No
No
No
Opera 66.0.3515.115
Windows 7
