Default encryption module
Since version 9.x I have a problem with the default encryption module (1.3.0), because for some reason it is automatically disabled, then I upgraded to version 10.x expecting this behavior to end but it continues. I have to enable it every day and i can’t make a clean installation because i have a lot of information. This installation is for a research institute at UNAM in México City.
I appreciate any help.
Operating system: Ubuntu Server 16.04.3 LTS
Web server: Apache/2.4.18
Database: MySQL 5.7.20
PHP version: 7.0.22
ownCloud version: 10.0.3
Updated from an older ownCloud or fresh install: Updated from version 9
Hola @zetagg,
The problem is fixed in 10.0.5.
You could use this patch to avoid the problem:
https://patch-diff.githubusercontent.com/raw/owncloud/core/pull/29870.patch
Saludos
Carlos
Hi @cdamken, thanks for the help.
Everything looks ok for the moment.
Saludos
Isset
