Working synchronization
Synchronization is broken after I have enabled TOTP. The sync failes with “Encryption not ready: Private key missing for user: please try to log-out and log-in again.”. Even after removing the account completely and starting a new sync (login/authentication goes fine, but after sync starts, for each and every file I get the above mentioned error message). However, the files on the server are fine, it’s possible to access/download them via the web interface.
Disabling TOTP for user or removing the TOTP app completely from owncloud does not solve the issue.
Server version 10.9.1, desktop client version 2.10.0.6519.
- add TOTP app to owncloud and enable TOTP for user
- try to sync account with desktop client (the best is to remove the account and let it sync from the beginning, you will get the errors on every file)
- try to disable TOTP and remove TOTP app completely
- still the same error.
Operating system: Debian 11
Web server: Apache 2.4.52
Database: MySQL 5.5.62
PHP version: 7.4
ownCloud version: 10.9.1
Client version: 2.10.0.6519
Operating system: Linux Mint 20.3
OS language: English
Qt version used by client package (Linux only, see also Settings dialog): 5.12.11
Client package (From ownCloud or distro) (Linux only): downloaded latest version (see above) from ownCloud, distro version also has the same problem
Installation path of client:
logs.
Client logfile:
02-15 15:42:03:287 [ warning sync.propagator ]: Could not complete propagation of “ownCloud Manual.pdf” by OCC::PropagateDownloadFile(0x563cdc696700) with status 9 and error: "Server replied “403 Forbidden” to “GET https:///remote.php/dav/files/test/ownCloud Manual.pdf" (Encryption not ready: Private Key missing for user: please try to log-out and log-in again)"
02-15 15:42:03:291 [ info sync.database ]: Closing DB "/home//ownCloud3/._sync_70686c598b68.db”
02-15 15:42:03:309 [ info sync.engine ]: CSync run took 480 ms
02-15 15:42:03:311 [ info gui.folder ]: Client version 2.5.1 Qt 5.12.8 SSL OpenSSL 1.1.1f 31 Mar 2020
02-15 15:42:03:313 [ info gui.folder ]: SyncEngine finished without problem.
02-15 15:42:03:314 [ info gui.folder ]: Folder sync result: 3
02-15 15:42:03:316 [ info gui.application ]: Sync state changed for folder "https:///remote.php/dav/files/test/" : “Success, some files were ignored.”
02-15 15:42:03:518 [ info gui.folder.manager ]: <========== Sync finished for folder [ownCloud3] of account [test@vps.2600.sk] with remote [https://remote.php/dav/files/test/]
02-15 15:42:04:640 [ info gui.updater ]: Skipping update check because of config file -
Web server error log:
no errors -
{“reqId”:“e0fb366c-ddac-444c-b2bf-139e480b4f3a”,“level”:2,“time”:“2022-02-15T14:42:02+00:00”,“remoteAddr”:“2001:4de8:fa41:36:1381:c025:1492:d156”,“user”:“test”,“app”:“no app in context”,“method”:“PROPFIND”,“url”:"/owncloud/remote.php/webdav/",“message”:“Could not decrypt the private key from user “test”” during login. Assume password change on the user back-end. Error message: Bad Signature"}
