Open OwnCloud web.
Click on a folder containing files.
Get error message “Directory not available, contact your administrator”
I should see the files, because in the client, they are there. Also: I didn’t delete anything.
I didn’t update and I didn’t share the folder. It is a folder where I keep my Zotero files, so it is used by the Zotero clients on my Mac and the Windows clients.
Can’t open the folder in the webpage. Also, I think syncing stopped in general because of this. I can add folders or folders through the website, but not through de client (on MacOS AND on Windows). The new files don’t show up in the client folders.
MacOS 10.14.2 (Mojave) (at home) / Windows 10 (at work)
MySQL
ownCloud 10.0.10 (stable)
Fresh install, not updated.
Result: “No errors have been found.”
No.
Are you using encryption:
No.
Webdav, for Zotero.
I tried Firefox, Chrome, Safari, but the problem is with the syncing of the client, so this is not relevant I think.
2019-02-09 19:16:01
Access
94.227.240.115
207
PROPFIND /owncloud/remote.php/dav/files/Taxicletter/ HTTP/1.0
1.08 K
Apache SSL/TLS access
2019-02-09 19:16:12
Access
94.227.240.115
207
1.10 K
2019-02-09 19:16:19
Access
94.227.240.115
207
1.08 K
2019-02-09 19:16:31
Access
94.227.240.115
207
1.08 K
2019-02-09 19:16:44
Access
94.227.240.115
207
1.10 K
2019-02-09 19:16:51
Access
94.227.240.115
207
1.10 K
2019-02-09 19:17:01
Access
94.227.240.115
207
1.08 K
2019-02-09 19:17:16
Access
94.227.240.115
207
1.10 K
2019-02-09 19:17:31
Access
94.227.240.115
207
1.08 K
2019-02-09 19:17:32
Access
94.227.240.115
200
GET /owncloud/ocs/v1.php/cloud/activity?page=0&pagesize=100&format=json HTTP/1.0
1.07 K
2019-02-09 19:17:32
Access
94.227.240.115
200
GET /owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.0
1.00 K
2019-02-09 19:17:48
Access
94.227.240.115
207
1.10 K
2019-02-09 19:18:01
Access
94.227.240.115
207
1.08 K
2019-02-09 19:18:20
Access
94.227.240.115
207
1.10 K
2019-02-09 19:18:28
Access
94.227.240.115
200
GET /owncloud/status.php HTTP/1.0
1.01 K
2019-02-09 19:18:28
Access
94.227.240.115
207
1.10 K
2019-02-09 19:18:28
Access
94.227.240.115
200
GET /owncloud/ocs/v1.php/cloud/capabilities?format=json HTTP/1.0
2.23 K
2019-02-09 19:18:28
Access
94.227.240.115
200
GET /owncloud/ocs/v1.php/cloud/user?format=json HTTP/1.0
1.04 K
2019-02-09 19:18:28
Access
94.227.240.115
200
GET /owncloud/remote.php/dav/avatars/Taxicletter/128.png HTTP/1.0
31.2 K
2019-02-09 19:18:28
Access
94.227.240.115
200
GET /owncloud/ocs/v1.php/config?format=json HTTP/1.0
1.00 K
2019-02-09 19:18:29
Access
94.227.240.115
200
1.00 K
2019-02-09 19:18:29
Access
94.227.240.115
207
7.85 K
2019-02-09 19:18:29
Access
94.227.240.115
207
PROPFIND /owncloud/remote.php/dav/files/Taxicletter/Documents HTTP/1.0
2.92 K
2019-02-09 19:18:30
Access
94.227.240.115
207
PROPFIND /owncloud/remote.php/dav/files/Taxicletter/Muziek HTTP/1.0
1.11 K
2019-02-09 19:18:30
Access
94.227.240.115
207
2.11 K
2019-02-09 19:18:30
Access
94.227.240.115
207
PROPFIND /owncloud/remote.php/dav/files/Taxicletter/Muziek/Tony%20Allen%20&%20Jeff%20Mills%20-%20Tomorrow%20Comes%20The%20Harvest HTTP/1.0
6.57 K
2019-02-09 19:18:30
Error
94.227.240.115
500
PROPFIND /owncloud/remote.php/dav/files/Taxicletter/zotero HTTP/1.0
13.1 K
2019-02-09 19:18:31
Access
94.227.240.115
207
1.08 K
2019-02-09 19:18:49
Access
94.227.240.115
207
1.10 K
Client log
09/02/2019 18:29:53,
ownCloud,Er trad een fout op bij het openen van een map zotero: Error transferring https://owncloud.taxiclette.be/owncloud/remote.php/dav/files/Taxicletter/zotero - server replied: Internal Server Error
