we use owncloud-client 2.9.2 on openSUSE Tumbleweed to synchronize with a owncloud server 10.9.1 on a debian machine.
I deleted a folder (incl. subfolders) on the client side, but this is not synchronized to the server, the folder still exists.
I run the client ond found in the logs:
###Logs
01-27 13:46:50:944 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary” | valid: true/false/db | mtime: 1643122550/0/0 | size: 0/0/0 | etag: “61f00f8c20379”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754355oc6ec311e4fc”//"" | inode: 713974/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:46:50:944 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:490 [ info sync.discovery ]: STARTING “service/software/Face/Project/aql1/Preliminary” OCC::ProcessDirectoryJob::ParentNotChanged “service/software/Face/Project/aql1/Preliminary” OCC::ProcessDirectoryJob::ParentDontExist
01-27 13:47:29:490 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 -6671746503308881156
01-27 13:47:29:490 [ debug sync.database.sql ] [ OCC::SqlQuery::exec ]: SQL exec “SELECT path, inode, modtime, type, md5, fileid, remotePerm, filesize, ignoredChildrenRemote, contentchecksumtype.name || ‘:’ || contentChecksum FROM metadata LEFT JOIN checksumtype as contentchecksumtype ON metadata.contentChecksumTypeId == contentchecksumtype.id WHERE parent_hash(path) = ?1 ORDER BY path||’/’ ASC”
01-27 13:47:29:490 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary/Ifc” | valid: true/false/db | mtime: 1643122526/0/0 | size: 0/0/0 | etag: “61f00f5e2163b”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754366oc6ec311e4fc”//"" | inode: 714225/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:47:29:490 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary/Ifc” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:490 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary/Ifc”
01-27 13:47:29:490 [ debug sync.database.sql ] [ OCC::SqlQuery::exec ]: SQL exec “SELECT lastTryEtag, lastTryModtime, retrycount, errorstring, lastTryTime, ignoreDuration, renameTarget, errorCategory, requestId FROM blacklist WHERE path=?1”
01-27 13:47:29:490 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary/abmd25” | valid: true/false/db | mtime: 1643122277/0/0 | size: 0/0/0 | etag: “61f00f6386eca”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754365oc6ec311e4fc”//"" | inode: 713975/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:47:29:490 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary/abmd25” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:490 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary/abmd25”
01-27 13:47:29:491 [ debug sync.database.sql ] [ OCC::SqlQuery::exec ]: SQL exec “SELECT lastTryEtag, lastTryModtime, retrycount, errorstring, lastTryTime, ignoreDuration, renameTarget, errorCategory, requestId FROM blacklist WHERE path=?1”
01-27 13:47:29:491 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary/aql1” | valid: true/false/db | mtime: 1643122530/0/0 | size: 0/0/0 | etag: “61f00f6cba3a2”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754364oc6ec311e4fc”//"" | inode: 714318/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:47:29:491 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary/aql1” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:491 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary/aql1”
01-27 13:47:29:491 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary/doc” | valid: true/false/db | mtime: 1643122482/0/0 | size: 0/0/0 | etag: “61f00f703ea7c”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754356oc6ec311e4fc”//"" | inode: 714626/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:47:29:491 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary/doc” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:491 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary/doc”
01-27 13:47:29:491 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary/dv3” | valid: true/false/db | mtime: 1643122303/0/0 | size: 0/0/0 | etag: “61f00f74c6314”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754412oc6ec311e4fc”//"" | inode: 714630/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:47:29:491 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary/dv3” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:491 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary/dv3”
01-27 13:47:29:491 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary/gpm3” | valid: true/false/db | mtime: 1643122550/0/0 | size: 0/0/0 | etag: “61f00f81050f4”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754413oc6ec311e4fc”//"" | inode: 714753/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:47:29:491 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary/gpm3” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:491 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary/gpm3”
01-27 13:47:29:491 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary/rcb” | valid: true/false/db | mtime: 1643122550/0/0 | size: 0/0/0 | etag: “61f00f8374d2b”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754416oc6ec311e4fc”//"" | inode: 714643/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:47:29:491 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary/rcb” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:491 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary/rcb”
01-27 13:47:29:491 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary/roadw4” | valid: true/false/db | mtime: 1643122425/0/0 | size: 0/0/0 | etag: “61f00f857ceed”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754415oc6ec311e4fc”//"" | inode: 714759/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:47:29:491 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary/roadw4” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:491 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary/roadw4”
01-27 13:47:29:491 [ info sync.discovery ]: Processing “service/software/Face/Project/aql1/Preliminary/rpt2” | valid: true/false/db | mtime: 1643122412/0/0 | size: 0/0/0 | etag: “61f00f8c20379”//"" | checksum: “”//"" | perm: “DNVCKR”//"" | fileid: “01754419oc6ec311e4fc”//"" | inode: 714492/0/ | type: CSyncEnums::ItemTypeDirectory/CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile
01-27 13:47:29:491 [ info sync.discovery ]: Discovered “service/software/Face/Project/aql1/Preliminary/rpt2” SyncInstruction(CSYNC_INSTRUCTION_REMOVE) OCC::SyncFileItem::Up CSyncEnums::ItemTypeDirectory
01-27 13:47:29:491 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary/rpt2”
01-27 13:47:29:491 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 “service/software/Face/Project/aql1/Preliminary”
01-27 13:47:29:527 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
01-27 13:47:29:527 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 3364382218146788245
01-27 13:47:29:527 [ debug sync.database.sql ] [ OCC::SqlQuery::exec ]: SQL exec “SELECT path, inode, modtime, type, md5, fileid, remotePerm, filesize, ignoredChildrenRemote, contentchecksumtype.name || ‘:’ || contentChecksum FROM metadata LEFT JOIN checksumtype as contentchecksumtype ON metadata.contentChecksumTypeId == contentchecksumtype.id WHERE phash=?1”
01-27 13:47:29:527 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 6920673164281981398
01-27 13:47:29:527 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 7019088352542083673
01-27 13:47:29:528 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 4971895933069133372
01-27 13:47:29:528 [ debug sync.database.sql ] [ OCC::SqlQuery::exec ]: SQL exec “SELECT path, inode, modtime, type, md5, fileid, remotePerm, filesize, ignoredChildrenRemote, contentchecksumtype.name || ‘:’ || contentChecksum FROM metadata LEFT JOIN checksumtype as contentchecksumtype ON metadata.contentChecksumTypeId == contentchecksumtype.id WHERE phash=?1”
01-27 13:47:29:528 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary/Ifc” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
01-27 13:47:29:528 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary/abmd25” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
01-27 13:47:29:528 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary/aql1” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
01-27 13:47:29:528 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary/doc” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
01-27 13:47:29:528 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary/dv3” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
01-27 13:47:29:528 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary/gpm3” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
01-27 13:47:29:528 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary/rcb” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
01-27 13:47:29:528 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary/roadw4” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
01-27 13:47:29:528 [ debug sync.statustracker ] [ OCC::SyncFileStatusTracker::slotAboutToPropagate ]: Investigating “service/software/Face/Project/aql1/Preliminary/rpt2” OCC::SyncFileItem::NoStatus SyncInstruction(CSYNC_INSTRUCTION_REMOVE)
I can’t find anything useful in the server log owncloud.log
Any hints how to find the cause?
Regards
Daniel
