Document Versioning keep forever
Dear Sir,
We need to keep document files all versioning over 20 years, I found the option configuration can be disable version:
“Disable Versions; no files will be deleted.”
Is it still keep all versions without delete? Or this option only disable versioning (no versions control)?
Regards,
Justinian
hi,
where did you find that option?
https://doc.owncloud.org/server/latest/admin_manual/configuration/files/file_versioning.html
both parameters D1, D2
have to be set to 20x365
you also have to have enough storage space.
