Duplicate folders
Owncloud create duplicated folders in web interface.
When i check in the server there is no duplicated file on the server…
How can i fix this issue in owncloud.
Same problem, especially when some files are moved, it is normally fix in owncloud 9.1.7 which is going to be released soon. Maybe Owncloud team will have a better answer.
Yes, I think this will be fixed in the new version
OK, I am guessing it is duplicate rows in the database, when I delete one entery it deletes both. Is there a way of fixing this by deleting duplicate records. I did a number od searches on the bug tracker (folder, duplicates, directories) and came up with nothing. Am I looking in the wrong place. I want to confirm if it has been fixed and see if there are any workrounds.
