I’m trying to install e2eeshare on an ownCloud 10.4.1. This app is not tagged as Enterprise but when I try installing it I’ve got:
e2eeshare: Installing new app ...
e2eeshare: Please enter a license-key in to config.php
It looks ownCloud is waiting for an Enterprise license key, am I right or should it be an e2eeshare license ? I doubt about that seconde idea since there is no link, no doc explaining how to buy this license.
I know it’s not an official ownCloud app, but someone might have an idea on how to solve this.
Thanks.
Cheers.
This is unfortunately an issue with the Marketplace App where AFAIK only two licenses are available: Open Source and OCL, where the latter requires an active enterprise key.
Since e2eeshare is not Open Source it only can be filed under the OCL license ATM.
In any case, e2eeshare is available for testing (with restriction to localhost as server name) when you download it directly from the market place and install it manually: https://marketplace.owncloud.com/apps/e2eeshare - sorry for the inconvenience.
For testing purposes no license key is required at all.
We are in contact with ownCloud to find a solution for the Marketplace App issue.
