Hi. When I install OwnCloud on my web server, I get error 403. This error is that I do not have permission, but I do not know how to fix it.
I would be very grateful if you could indicate how I can install OwnCloud or what I still need to do.
Thanks in advance.
Hi, can you please fill out the issue template?
it makes it far easier for others to help you solve your problem.
Can you give us the following infos:
Thanks for reporting issues back to ownCloud! This is the issue tracker of ownCloud, if you have any support question please check out https://owncloud.org/support
This is the bug tracker for the Server component. Find other components at https://github.com/owncloud/core/blob/master/.github/CONTRIBUTING.md#guidelines
For reporting potential security issues please see https://owncloud.org/security/
To make it possible for us to help you please fill out below information carefully.
Before reporting any issues please make sure that you're using the latest available version for your major branch (e.g. 9.0.x), see https://owncloud.org/changelog/
### Steps to reproduce
1.
2.
3.
### Expected behaviour
### Actual behaviour
### Server configuration
**Operating system**:
**Web server:**
**Database:**
**PHP version:**
**List of activated apps:**
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
just copy & paste this to your next reply, remove the backslashes (\), and substitute the necessary information.
