New to Linux etc and have done well up till now. I have changed the config.php file to store data to /media/harry/My Book/Owncloud
but I'm hitting this error now -
Data directory (/media/harry/My Book/Owncloud) is invalid
Please check that the data directory contains a file ".ocdata" in its root.
Any help?
Reason for changing directory is, I'm hosting Ubuntu on virtualBox to decide if I like it or not, and have set the HDD at 4gb, which isn't enough to upload my pics, I have a 1tb external drive that I wish to use for the storage instead?
Please be aware that moving the datadir is currently not supported:
so its the best to start from scratch and directly choose the external disc as a datadir during the setup.
The issue itself is most likely caused by the NTFS fileformat and wrong permissions on that. On such discs you need to choose correct permissions during the mount of it. The linux command:
man mount
or some tutorials about mounting NTFS discs should lead you to the info how to mount that device correctly with the user of your webserver as the owner.
So this is a starting point where the infos posted above will support you with that task to give your webservers user the correct permissions to access this external device.
