hi, sure.
I can give you the description of another request ID, generated with the same operation (user logging with the web interface). Please note that I removed the user email for privacy reasons
{“reqId”:“060ef6d5-4c0c-4a82-ad4b-d1523e2d45e7”,“level”:3,“time”:“2018-03-15T13:26:54+00:00”,“remoteAddr”:“213.215.247.34”,“user”:“–”,“app”:“PHP”,“method”:“PROPFIND”,“url”:“/remote.php/webdav/”,“message”:“Call to a member function getUID() on null at /var/www/vhosts/imcdcloud.com/httpdocs/lib/private/legacy/app.php#152”}
{“reqId”:“Wqp0rRZ6n0otqrsSpu1RcQAAAQs”,“level”:2,“time”:“2018-03-15T13:27:09+00:00”,“remoteAddr”:“213.215.247.34”,“user”:“–”,“app”:“core”,“method”:“POST”,“url”:“/index.php/login”,“message”:“Login failed: ‘’ (Remote IP: ‘213.215.247.34’)”}
{“reqId”:“Wqp0sxZ6n0otqrsSpu1RewAAAQw”,“level”:3,“time”:“2018-03-15T13:27:15+00:00”,“remoteAddr”:“213.215.247.34”,“user”:“”,“app”:“index”,“method”:“GET”,“url”:“/index.php/apps/files/”,“message”:“Exception: {"Exception":"OCP\\Files\\NotFoundException","Message":"","Code":0,"Trace":"#0 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Files\/Node\/Node.php(217): OC\\Files\\Node\\Node->getFileInfo()\n#1 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Files\/Node\/Node.php(117): OC\\Files\\Node\\Node->getPermissions()\n#2 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Files\/Node\/Folder.php(151): OC\\Files\\Node\\Node->checkPermissions(4)\n#3 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AvatarManager.php(99): OC\\Files\\Node\\Folder->newFolder(‘18’)\n#4 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AvatarManager.php(120): OC\\AvatarManager->getFolder(Object(OC\\Files\\Node\\Folder), ‘18’)\n#5 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AvatarManager.php(91): OC\\AvatarManager->getAvatarFolder(Object(OC\\User\\User))\n#6 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/TemplateLayout.php(101): OC\\AvatarManager->getAvatar(‘’)\n#7 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/legacy\/template.php(234): OC\\TemplateLayout->__construct(‘user’, ‘files’)\n#8 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/public\/AppFramework\/Http\/TemplateResponse.php(156): OC_Template->fetchPage()\n#9 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AppFramework\/Http\/Dispatcher.php(112): OCP\\AppFramework\\Http\\TemplateResponse->render()\n#10 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AppFramework\/App.php(103): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\Files\\Controller\\ViewController), ‘index’)\n#11 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(46): OC\\AppFramework\\App::main(‘ViewController’, ‘index’, Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#12 [internal function]: OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#13 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Route\/Router.php(342): call_user_func(Object(OC\\AppFramework\\Routing\\RouteActionHandler), Array)\n#14 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/base.php(913): OC\\Route\\Router->match(‘\/apps\/files\/’)\n#15 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/index.php(55): OC::handleRequest()\n#16 {main}","File":"\/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Files\/Node\/Node.php","Line":97}”}
{“reqId”:“Wqp0tRoZOJ-EAbGiLL7mxwAAAFg”,“level”:3,“time”:“2018-03-15T13:27:18+00:00”,“remoteAddr”:“213.215.247.34”,“user”:“”,“app”:“index”,“method”:“GET”,“url”:“/index.php/apps/files/”,“message”:“Exception: {"Exception":"OCP\\Files\\NotFoundException","Message":"","Code":0,"Trace":"#0 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Files\/Node\/Node.php(217): OC\\Files\\Node\\Node->getFileInfo()\n#1 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Files\/Node\/Node.php(117): OC\\Files\\Node\\Node->getPermissions()\n#2 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Files\/Node\/Folder.php(151): OC\\Files\\Node\\Node->checkPermissions(4)\n#3 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AvatarManager.php(99): OC\\Files\\Node\\Folder->newFolder(‘18’)\n#4 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AvatarManager.php(120): OC\\AvatarManager->getFolder(Object(OC\\Files\\Node\\Folder), ‘18’)\n#5 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AvatarManager.php(91): OC\\AvatarManager->getAvatarFolder(Object(OC\\User\\User))\n#6 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/TemplateLayout.php(101): OC\\AvatarManager->getAvatar(‘’)\n#7 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/legacy\/template.php(234): OC\\TemplateLayout->__construct(‘user’, ‘files’)\n#8 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/public\/AppFramework\/Http\/TemplateResponse.php(156): OC_Template->fetchPage()\n#9 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AppFramework\/Http\/Dispatcher.php(112): OCP\\AppFramework\\Http\\TemplateResponse->render()\n#10 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AppFramework\/App.php(103): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\Files\\Controller\\ViewController), ‘index’)\n#11 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(46): OC\\AppFramework\\App::main(‘ViewController’, ‘index’, Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#12 [internal function]: OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#13 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Route\/Router.php(342): call_user_func(Object(OC\\AppFramework\\Routing\\RouteActionHandler), Array)\n#14 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/base.php(913): OC\\Route\\Router->match(‘\/apps\/files\/’)\n#15 \/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/index.php(55): OC::handleRequest()\n#16 {main}","File":"\/var\/www\/vhosts\/imcdcloud.com\/httpdocs\/lib\/private\/Files\/Node\/Node.php","Line":97}”}
