Error after upgrade
After updating this screen appears, I perform the steps of changing the maintenance off from ftp in the config.php, I try again the update and I get the same screen that remains hours and hours and does not move from there
Make sure that you’re following exactly all steps provided here:
you should try command upgrade, i upgrade success follow manual.
