1.Connect to the owncloud platform via web interface
2.Disconnect session from the logout link
3.
When I click on the logout link, the session should be destroy and redirect to the authentification page
The disconnect display the error : Deny access - CSRF check failed Expected behaviour
Operating system: Linux OVH Shared web hosting
Web server: Apache/2.4.
Database: Mysql
PHP version: 7.0
ownCloud version: 10.0.2
Where did you install ownCloud from: Php ownCloud install page on shared web hosting
Signing status (ownCloud 9.0 and above): No errors have
paste the results into https://gist.github.com/ and puth the link here
anonymous/gist:c7b5783d5019d34151b7a2f67ed1df50
<?php $CONFIG = array ( 'instanceid' => 'ocouig20l6zz', 'passwordsalt' => 'hkkaeQltxvDP/A0DIb4S3dM6B6KbGL', 'secret' => 'UYlec4DTo1XylbhRD69kDr6c5DcEIoMVBK6LB+WqYn5axr1x', 'trusted_domains' => array ( 0 => 'cloud.pensora.fr', ), 'datadirectory' => '/home/pensorafgn/wwwown/data', 'overwrite.cli.url' => 'https://cloud.pensora.fr', 'dbtype' => 'mysql', 'version' => '10.0.2.1', 'dbname' => '****************, 'dbhost' => '*****************', 'dbtableprefix' => 'oc_', 'dbuser' => '************', 'dbpassword' => '***************', 'logtimezone' => 'UTC', 'installed' => true, 'session_lifetime' => 60, ); ``` Log in to the web-UI with an administrator account and click on 'admin' -> 'Generate Config Report' -> 'Download ownCloud config report' This report includes the config.php settings, the list of activated apps and other details in a well sanitized form. or If you have access to your command line run e.g.: sudo -u www-data php occ config:list system from within your ownCloud installation folder *ATTENTION:* Do not post your config.php file in public as is. Please use one of the above methods whenever possible. Both, the generated reports from the web-ui and from occ config:list consistently remove sensitive data. You still may want to review the report before sending. If done manually then it is critical for your own privacy to dilligently remove *all* host names, passwords, usernames, salts and other credentials before posting. You should assume that attackers find such information and will use them against your systems. ``` **List of activated apps:** none additional ``` If you have access to your command line run e.g.: sudo -u www-data php occ app:list from within your ownCloud installation folder. ``` **Are you using external storage, if yes which one:** No... **Are you using encryption:** no **Are you using an external user-backend, if yes which one:** No... ### Client configuration **Browser:** Firefox & Chrome **Operating system:** Windows 8.1 ### Logs #### Web server error log ``` " 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:35:46 +0200] "GET /cron.php HTTP/1.1" 200 20 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.101 Safari/537.36" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:35:46 +0200] "GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 74 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.101 Safari/537.36" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:35:46 +0200] "GET /index.php/avatar/Tests-OC/42 HTTP/1.1" 200 35 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.101 Safari/537.36" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:35:46 +0200] "PROPFIND /remote.php/webdav/ HTTP/1.1" 207 4885 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.101 Safari/537.36" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:35:46 +0200] "PROPFIND /remote.php/webdav/ HTTP/1.1" 207 4885 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.101 Safari/537.36" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:35:47 +0200] "GET /index.php/avatar/Tests-OC/42 HTTP/1.1" 200 35 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.101 Safari/537.36" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:35:47 +0200] "GET /index.php/apps/files/ajax/getstoragestats.php?dir=%2F HTTP/1.1" 200 185 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.101 Safari/537.36" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:35:47 +0200] "GET /index.php/avatar/Tests-OC/42 HTTP/1.1" 200 35 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.101 Safari/537.36" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:13 +0200] "GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 74 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:16 +0200] "GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 74 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.101 Safari/537.36" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:18 +0200] "GET /index.php/logout?requesttoken=PxU2NFZmBAAiKAh/LB0LWAV0Ny1TAiI9NQkMBSE2EjE%3D%3ATfDm1ImMigyOkWG0F1ml6GkPDeKmiQByz/BSGJTkHKs%3D HTTP/1.1" 302 295 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:18 +0200] "GET /index.php/logout?requesttoken=PxU2NFZmBAAiKAh/LB0LWAV0Ny1TAiI9NQkMBSE2EjE%253D%253ATfDm1ImMigyOkWG0F1ml6GkPDeKmiQByz/BSGJTkHKs%253D HTTP/1.1" 412 1613 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:19 +0200] "GET /index.php/core/js/oc.js?v=e81ad89ccd551814ed7c72139b5cf64d HTTP/1.1" 200 1147 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:19 +0200] "GET /core/img/background.jpg HTTP/1.1" 200 133536 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:19 +0200] "GET /core/img/logo-icon.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:19 +0200] "GET /apps/notifications/img/notifications.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:19 +0200] "GET /cron.php HTTP/1.1" 200 20 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:19 +0200] "GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 74 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:31 +0200] "GET / HTTP/1.1" 302 25 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:31 +0200] "GET /index.php/apps/files/ HTTP/1.1" 302 199 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:31 +0200] "GET /index.php/apps/files/ HTTP/1.1" 200 4767 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /index.php/core/js/oc.js?v=e81ad89ccd551814ed7c72139b5cf64d HTTP/1.1" 200 1147 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /settings/img/admin.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /settings/img/help.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /core/img/actions/logout.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /apps/files/img/app.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /apps/files/img/folder.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /settings/img/users.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /cron.php HTTP/1.1" 200 20 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 74 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /core/img/actions/search-white.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" 78.231.132.89 cloud.pensora.fr - [18/Aug/2017:10:36:32 +0200] "GET /apps/market/img/market.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:54.0) Gecko/20100101 Firefox/54.0" #### ownCloud log (data/owncloud.log) ``` I{"reqId":"WZWxgQoUFBkAABrhehAAAAA3","level":3,"time":"2017-08-17T15:08:50+00:00","remoteAddr":"78.231.132.89","user":"--","app":"PHP","method":"GET","url":"\/","message":"chmod(): No such file or directory at \/home\/pensorafgn\/wwwown\/lib\/private\/Log\/Owncloud.php#122"} {"reqId":"WZWzfgoUFBkAABrhhFMAAAAf","level":3,"time":"2017-08-17T15:17:18+00:00","remoteAddr":"78.231.132.89","user":"--","app":"PHP","method":"POST","url":"\/index.php","message":"Zend OPcache API is restricted by \"restrict_api\" configuration directive at \/home\/pensorafgn\/wwwown\/lib\/private\/legacy\/util.php#1349"} {"reqId":"WZWzfgoUFBkAABrhhFMAAAAf","level":3,"time":"2017-08-17T15:17:18+00:00","remoteAddr":"78.231.132.89","user":"--","app":"PHP","method":"POST","url":"\/index.php","message":"Zend OPcache API is restricted by \"restrict_api\" configuration directive at \/home\/pensorafgn\/wwwown\/lib\/private\/legacy\/util.php#1349"} {"reqId":"WZW25goUFBkAABrhls0AAAAn","level":3,"time":"2017-08-17T15:31:51+00:00","remoteAddr":"78.231.132.89","user":"--","app":"PHP","method":"POST","url":"\/index.php","message":"Zend OPcache API is restricted by \"restrict_api\" configuration directive at \/home\/pensorafgn\/wwwown\/lib\/private\/legacy\/util.php#1349"} {"reqId":"WZW25goUFBkAABrhls0AAAAn","level":3,"time":"2017-08-17T15:31:51+00:00","remoteAddr":"78.231.132.89","user":"--","app":"PHP","method":"POST","url":"\/index.php","message":"Zend OPcache API is restricted by \"restrict_api\" configuration directive at \/home\/pensorafgn\/wwwown\/lib\/private\/legacy\/util.php#1349"} {"reqId":"WZW25goUFBkAABrhls0AAAAn","level":3,"time":"2017-08-17T15:31:52+00:00","remoteAddr":"78.231.132.89","user":"--","app":"mysql.setup","method":"POST","url":"\/index.php","message":"Specific user creation failed: An exception occurred while executing 'SELECT user FROM mysql.user WHERE user=?' with params [\"oc_Admin-cloud\"]:\n\nSQLSTATE[42000]: Syntax error or access violation: 1142 SELECT command denied to user 'pensorafgnadmin'@'10.2.100.25' for table 'user'"} {"reqId":"WZW25goUFBkAABrhls0AAAAn","level":3,"time":"2017-08-17T15:31:52+00:00","remoteAddr":"78.231.132.89","user":"--","app":"PHP","method":"POST","url":"\/index.php","message":"Zend OPcache API is restricted by \"restrict_api\" configuration directive at \/home\/pensorafgn\/wwwown\/lib\/private\/legacy\/util.php#1349"} {"reqId":"WZW25goUFBkAABrhls0AAAAn","level":3,"time":"2017-08-17T15:31:55+00:00","remoteAddr":"78.231.132.89","user":"--","app":"PHP","method":"POST","url":"\/index.php","message":"Zend OPcache API is restricted by \"restrict_api\" configuration directive at \/home\/pensorafgn\/wwwown\/lib\/private\/legacy\/util.php#1349"} {"reqId":"WZW25goUFBkAABrhls0AAAAn","level":3,"time":"2017-08-17T15:31:55+00:00","remoteAddr":"78.231.132.89","user":"--","app":"PHP","method":"POST","url":"\/index.php","message":"Zend OPcache API is restricted by \"restrict_api\" configuration directive at \/home\/pensorafgn\/wwwown\/lib\/private\/legacy\/util.php#1349"} {"reqId":"WZW3KwoUFBkAABrhmA4AAAAt","level":2,"time":"2017-08-17T15:33:00+00:00","remoteAddr":"78.231.132.89","user":"--","app":"core","method":"POST","url":"\/index.php\/login?redirect_url=%252Findex.php%252Fapps%252Ffiles%252F","message":"Login failed: 'Admin-cloud' (Remote IP: '78.231.132.89')"} {"reqId":"WZaKuQoUFAsAAGqWvXQAAAAo","level":4,"time":"2017-08-18T06:35:38+00:00","remoteAddr":"78.231.132.89","user":"Admin-cloud","app":"webdav","method":"DELETE","url":"\/remote.php\/webdav\/Photos\/Squirrel.jpg","message":"Exception: {\"Message\":\"An exception occurred while executing 'INSERT INTO `oc_filecache` (`mimepart`,`mimetype`,`mtime`,`size`,`etag`,`storage_mtime`,`permissions`,`checksum`,`path_hash`,`path`,`parent`,`name`,`storage`) SELECT ?,?,?,?,?,?,?,?,?,?,?,?,? FROM `oc_filecache` WHERE `storage` = ? AND `path_hash` = ? HAVING COUNT(*) = 0' with params [\\\"1\\\", \\\"2\\\", 1503038138, -1, \\\"59968aba22b25\\\", 1503038138, 31, \\\"\\\", \\\"fb66dca5f27af6f15c1d1d81e6f8d28b\\\", \\\"files_trashbin\\\", 1, \\\"files_trashbin\\\", 1, 1, \\\"fb66dca5f27af6f15c1d1d81e6f8d28b\\\"]:\\n\\nSQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '1-fb66dca5f27af6f15c1d1d81e6f8d28b' for key 'fs_storage_path_hash'\",\"Exception\":\"Doctrine\\\\DBAL\\\\Exception\\\\UniqueConstraintViolationException\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/DBALException.php(128): Doctrine\\\\DBAL\\\\Driver\\\\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOException))\\n#1 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(1015): Doctrine\\\\DBAL\\\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOMySql\\\\Driver), Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOException), 'INSERT INTO `oc...', Array)\\n#2 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/DB\\\/Connection.php(211): Doctrine\\\\DBAL\\\\Connection->executeUpdate('INSERT INTO `oc...', Array, Array)\\n#3 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/DB\\\/Adapter.php(113): OC\\\\DB\\\\Connection->executeUpdate('INSERT INTO `oc...', Array)\\n#4 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/DB\\\/Connection.php(249): OC\\\\DB\\\\Adapter->insertIfNotExist('*PREFIX*filecac...', Array, Array)\\n#5 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/Cache\\\/Cache.php(263): OC\\\\DB\\\\Connection->insertIfNotExist('*PREFIX*filecac...', Array, Array)\\n#6 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/Cache\\\/Cache.php(220): OC\\\\Files\\\\Cache\\\\Cache->insert('files_trashbin', Array)\\n#7 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(266): OC\\\\Files\\\\Cache\\\\Cache->put('files_trashbin', Array)\\n#8 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(206): OC\\\\Files\\\\Cache\\\\Scanner->addToCache('files_trashbin', Array, -1)\\n#9 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(309): OC\\\\Files\\\\Cache\\\\Scanner->scanFile('files_trashbin', 3, '1', false, false)\\n#10 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/Cache\\\/Updater.php(124): OC\\\\Files\\\\Cache\\\\Scanner->scan('files_trashbin', false, 3, false)\\n#11 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/View.php(314): OC\\\\Files\\\\Cache\\\\Updater->update('files_trashbin', 1503038138)\\n#12 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/View.php(1138): OC\\\\Files\\\\View->writeUpdate(Object(OCA\\\\Files_Trashbin\\\\Storage), 'files_trashbin')\\n#13 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/View.php(262): OC\\\\Files\\\\View->basicOperation('mkdir', '\\\/files_trashbin', Array)\\n#14 \\\/home\\\/pensorafgn\\\/wwwown\\\/apps\\\/files_trashbin\\\/lib\\\/Trashbin.php(150): OC\\\\Files\\\\View->mkdir('files_trashbin')\\n#15 \\\/home\\\/pensorafgn\\\/wwwown\\\/apps\\\/files_trashbin\\\/lib\\\/Trashbin.php(250): OCA\\\\Files_Trashbin\\\\Trashbin::setUpTrash('Admin-cloud')\\n#16 \\\/home\\\/pensorafgn\\\/wwwown\\\/apps\\\/files_trashbin\\\/lib\\\/Storage.php(185): OCA\\\\Files_Trashbin\\\\Trashbin::move2trash('Photos\\\/Squirrel...')\\n#17 \\\/home\\\/pensorafgn\\\/wwwown\\\/apps\\\/files_trashbin\\\/lib\\\/Storage.php(120): OCA\\\\Files_Trashbin\\\\Storage->doDelete('files\\\/Photos\\\/Sq...', 'unlink')\\n#18 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/View.php(1123): OCA\\\\Files_Trashbin\\\\Storage->unlink('files\\\/Photos\\\/Sq...')\\n#19 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/private\\\/Files\\\/View.php(693): OC\\\\Files\\\\View->basicOperation('unlink', '\\\/Photos\\\/Squirre...', Array)\\n#20 \\\/home\\\/pensorafgn\\\/wwwown\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(346): OC\\\\Files\\\\View->unlink('\\\/Photos\\\/Squirre...')\\n#21 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(179): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->delete()\\n#22 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(287): Sabre\\\\DAV\\\\Tree->delete('Photos\\\/Squirrel...')\\n#23 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpDelete(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#24 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#25 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:DELETE', Array)\\n#26 \\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#27 \\\/home\\\/pensorafgn\\\/wwwown\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(63): Sabre\\\\DAV\\\\Server->exec()\\n#28 \\\/home\\\/pensorafgn\\\/wwwown\\\/remote.php(165): require_once('\\\/home\\\/pensorafg...')\\n#29 {main}\",\"File\":\"\\\/home\\\/pensorafgn\\\/wwwown\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Driver\\\/AbstractMySQLDriver.php\",\"Line\":66,\"User\":\"Admin-cloud\"}"} {"reqId":"WZaM2AoUFAsAAGqWxo8AAAAA","level":2,"time":"2017-08-18T06:44:41+00:00","remoteAddr":"78.231.132.89","user":"--","app":"core","method":"PROPFIND","url":"\/remote.php\/webdav\/","message":"Login failed: 'Admin-cloud' (Remote IP: '78.231.132.89')"} {"reqId":"WZaM7QoUFAsAAGqWxs0AAAA8","level":2,"time":"2017-08-18T06:45:02+00:00","remoteAddr":"78.231.132.89","user":"--","app":"core","method":"PROPFIND","url":"\/remote.php\/webdav\/","message":"Login failed: 'Admin-cloud' (Remote IP: '78.231.132.89')"} {"reqId":"WZaNRQoUFAsAAGqWyIIAAAAG","level":2,"time":"2017-08-18T06:46:30+00:00","remoteAddr":"78.231.132.89","user":"--","app":"core","method":"PROPFIND","url":"\/remote.php\/webdav\/","message":"Login failed: 'Admin-cloud' (Remote IP: '78.231.132.89')"} {"reqId":"WZaNSAoUFAsAAGqWyIgAAAAy","level":2,"time":"2017-08-18T06:46:32+00:00","remoteAddr":"78.231.132.89","user":"--","app":"core","method":"PROPFIND","url":"\/remote.php\/webdav\/","message":"Login failed: 'Admin-cloud' (Remote IP: '78.231.132.89')"} {"reqId":"WZaNYQoUFAsAAGqWyNUAAAAt","level":2,"time":"2017-08-18T06:46:57+00:00","remoteAddr":"78.231.132.89","user":"--","app":"core","method":"PROPFIND","url":"\/remote.php\/webdav\/","message":"Login failed: 'Admin-cloud' (Remote IP: '78.231.132.89')"} {"reqId":"WZaV7AoUFAsAAA1GHSsAAAAu","level":2,"time":"2017-08-18T07:23:24+00:00","remoteAddr":"78.231.132.89","user":"--","app":"core","method":"PROPFIND","url":"\/remote.php\/webdav\/","message":"Login failed: 'Admin-cloud' (Remote IP: '78.231.132.89')"} {"reqId":"WZawNAoUFAsAAC-kSecAAACY","level":2,"time":"2017-08-18T09:15:32+00:00","remoteAddr":"78.231.132.89","user":"Admin-cloud","app":"core","method":"GET","url":"\/index.php\/apps\/files\/?dir=\/&fileid=3","message":"Trusted domain error. \"78.231.132.89\" tried to access using \"cloud.pensora.fr\" as host."} {"reqId":"WZawNQoUFAsAACBFjQQAAABD","level":2,"time":"2017-08-18T09:15:33+00:00","remoteAddr":"78.231.132.89","user":"Admin-cloud","app":"core","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=e81ad89ccd551814ed7c72139b5cf64d","message":"Trusted domain error. \"78.231.132.89\" tried to access using \"cloud.pensora.fr\" as host."} {"reqId":"WZawNQoUFAsAACBFjQUAAABy","level":2,"time":"2017-08-18T09:15:33+00:00","remoteAddr":"78.231.132.89","user":"Admin-cloud","app":"core","method":"GET","url":"\/cron.php","message":"Trusted domain error. \"78.231.132.89\" tried to access using \"cloud.pensora.fr\" as host."} {"reqId":"WZawOQoUFAsAAC-kSgUAAAC3","level":2,"time":"2017-08-18T09:15:37+00:00","remoteAddr":"78.231.132.89","user":"Tests-OC","app":"core","method":"GET","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","message":"Trusted domain error. \"78.231.132.89\" tried to access using \"cloud.pensora.fr\" as host."} {"reqId":"WZawRQoUFAsAACBFjVEAAABe","level":2,"time":"2017-08-18T09:15:50+00:00","remoteAddr":"78.231.132.89","user":"svalentin","app":"core","method":"PROPFIND","url":"\/remote.php\/dav\/files\/svalentin\/","message":"Trusted domain error. \"78.231.132.89\" tried to access using \"cloud.pensora.fr\" as host."} {"reqId":"WZawRgoUFAsAACBFjVIAAABh","level":2,"time":"2017-08-18T09:15:50+00:00","remoteAddr":"78.231.132.89","user":"Tests-OC","app":"core","method":"PROPFIND","url":"\/remote.php\/dav\/files\/Tests-OC\/","message":"Trusted domain error. \"78.231.132.89\" tried to access using \"cloud.pensora.fr\" as host."} {"reqId":"WZawUQoUFAsAAC-kSksAAACM","level":2,"time":"2017-08-18T09:16:01+00:00","remoteAddr":"78.231.132.89","user":"svalentin","app":"core","method":"PROPFIND","url":"\/remote.php\/dav\/files\/svalentin\/","message":"Trusted domain error. \"78.231.132.89\" tried to access using \"cloud.pensora.fr\" as host."} {"reqId":"WZawUQoUFAsAAC-kSkwAAAC-","level":2,"time":"2017-08-18T09:16:01+00:00","remoteAddr":"78.231.132.89","user":"Tests-OC","app":"core","method":"PROPFIND","url":"\/remote.php\/dav\/files\/Tests-OC\/","message":"Trusted domain error. \"78.231.132.89\" tried to access using \"cloud.pensora.fr\" as host."} ``` #### Browser log ``` I don't know where to find those informations ```
