We installed the latest owncloud () and get thesee error messsages: 3 times 500 Internal Server Error, 1 time 423 Locked
Here is the log:
222362fbd59c",“level”:3,“time”:“2020-10-19T08:25:50+00:00”,“remoteAddr”:“192.168.0.129”,“user”:“sebastian”,“app”:“webdav”,“method”:“GET”,“url”:"/remote.php/dav/files/sebastian/Electrical%20Designs/kicad_komponenten/Emqopter_components.pretty/3dParts/FFC%201mm/FFC_Connector_1mm_10Pin.FCStd",“message”:“Caused by: {“Exception”:“PDOException”,“Message”:“SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘files\/0a3483c2d2575aca1ce15c2d24169714’ for key ‘lock_key_index’”,“Code”:“23000”,“Trace”:”#0 \/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php(127): PDOStatement->execute(NULL)\n#1 \/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php(1062): Doctrine\\DBAL\\Driver\\PDOStatement->execute()\n#2 \/var\/www\/owncloud\/lib\/private\/DB\/Connection.php(207): Doctrine\\DBAL\\Connection->executeUpdate(‘INSERT INTO oc...', Array, Array)\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/DB\\\/Adapter.php(116): OC\\\\DB\\\\Connection->executeUpdate('INSERT INTO
oc…’, Array)\n#4 \/var\/www\/owncloud\/lib\/private\/DB\/Connection.php(245): OC\\DB\\Adapter->insertIfNotExist(‘PREFIXfile_lo…’, Array, Array)\n#5 \/var\/www\/owncloud\/lib\/private\/Lock\/DBLockingProvider.php(118): OC\\DB\\Connection->insertIfNotExist(‘PREFIXfile_lo…’, Array, Array)\n#6 \/var\/www\/owncloud\/lib\/private\/Lock\/DBLockingProvider.php(166): OC\\Lock\\DBLockingProvider->initLockField(‘files\/0a3483c2d…’, 1)\n#7 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(661): OC\\Lock\\DBLockingProvider->acquireLock(‘files\/0a3483c2d…’, 1)\n#8 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(592): OC\\Files\\Storage\\Common->acquireLock(‘files\/Electrica…’, 1, Object(OC\\Lock\\DBLockingProvider))\n#9 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(592): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock(‘files\/Electrica…’, 1, Object(OC\\Lock\\DBLockingProvider))\n#10 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(592): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock(‘files\/Electrica…’, 1, Object(OC\\Lock\\DBLockingProvider))\n#11 \/var\/www\/owncloud\/apps\/files_sharing\/lib\/SharedStorage.php(380): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock(‘files\/Electrica…’, 1, Object(OC\\Lock\\DBLockingProvider))\n#12 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(592): OCA\\Files_Sharing\\SharedStorage->acquireLock(‘kicad_komponent…’, 1, Object(OC\\Lock\\DBLockingProvider))\n#13 \/var\/www\/owncloud\/lib\/private\/Files\/View.php(2037): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock(‘kicad_komponent…’, 1, Object(OC\\Lock\\DBLockingProvider))\n#14 \/var\/www\/owncloud\/lib\/private\/Files\/View.php(2144): OC\\Files\\View->lockPath(’\/Electrical Des…’, 1)\n#15 \/var\/www\/owncloud\/lib\/private\/Files\/View.php(1208): OC\\Files\\View->lockFile(’\/Electrical Des…’, 1)\n#16 \/var\/www\/owncloud\/lib\/private\/Files\/View.php(1066): OC\\Files\\View->basicOperation(‘fopen’, ‘\/Electrical Des…’, Array, ‘rb’)\n#17 \/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php(395): OC\\Files\\View->fopen(‘Electrical Desi…’, ‘rb’)\n#18 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/CorePlugin.php(85): OCA\\DAV\\Connector\\Sabre\\File->get()\n#19 \/var\/www\/owncloud\/lib\/composer\/sabre\/event\/lib\/WildcardEmitterTrait.php(89): Sabre\\DAV\\CorePlugin->httpGet(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#20 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(470): Sabre\\DAV\\Server->emit(‘method:GET’, Array)\n#21 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(251): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#22 \/var\/www\/owncloud\/apps\/dav\/lib\/Server.php(329): Sabre\\DAV\\Server->start()\n#23 \/var\/www\/owncloud\/apps\/dav\/appinfo\/v2\/remote.php(31): OCA\\DAV\\Server->exec()\n#24 \/var\/www\/owncloud\/remote.php(165): require_once(’\/var\/www\/ownclo…’)\n#25 {main}",“File”:"\/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php",“Line”:127}"}
