1.Download last Esxi version -> https://appcenter.software-univention.de/univention-apps/current/owncloud/Univention-App-owncloud-ESX.ova
2.Deploy the appliance in my esxi host v7
3.start the VM
the vm should be start normally
I get an error message -> so far the authentication failed, continuing nevertheless
Appliance OS
Appliance Web server
N.A
N.A
10.3.2
fresh install
