Hi.
is there a chance to get an expiration date function also for users ?
This would be a helpful feature for using ownCloud with many external users and an additional security feature.
Thank you.
Best regards. Holger
Hi.
Thank you.
Hi Holger,
Depends on what you want to achieve.
There are a bunch of occ commands that could be helpful in programming a little cron one-liner to automatically disable inactive users:
https://doc.owncloud.com/server/10.2/admin_manual/configuration/server/occ_command.html#finding-inactive-users
https://doc.owncloud.com/server/10.2/admin_manual/configuration/server/occ_command.html#disable-users
A one-liner could look like this:
occ user:inactive 90 | grep uid | awk '"'"'{print $3}'"'"' | while read user; do occ user:disable ${user}; done;
I would recommend to only disable users, as their data would immediately get deleted if you use user:delete
Make sure you test your cron job properly in a safe environment before accidentally deleting/disabling production users.
Super. Perfect. This works for me.
