- Add external storage, select local type, use a NFS mounted storage drive as the oc-data location.
- Add files to OwnCloud on that external storage just created.
- Check folder size reported in OwnCloud and compare against the original folder size. If the numbers don’t match, that is the issue here.
Folder size reported on owncloud should match the actual folder size.
Folder size reported on owncloud tends to be 10-20% smaller than the actual size.
Ubuntu 14.04
Apache
MySQL
PHP 7.0.21-1~ubuntu14.04.1+deb.sury.org+1 (cli) (built: Jul 6 2017 09:38:10) ( NTS )
10.0.4.4
I perform regular upgrades.
The original install was 9.x.
I forget.
"system": {
"instanceid": "oc00zt3t7bwy",
"trusted_domains": [
"owncloud.xxx.xxx",
"owncloud.xxx.xxx"
"datadirectory": "\/cache\/data",
"overwrite.cli.url": "https:\/\/owncloud.xxx.xxx",
"htaccess.RewriteBase": "\/",
"dbtype": "mysql",
"version": "10.0.4.4",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"loglevel": 0,
"files_external_allow_create_new_local": "true",
"redis": {
"host": "localhost",
"port": 6379
"appstore.experimental.enabled": true,
"enable_previews": "true",
"preview_libreoffice_path": "\/usr\/bin\/libreoffice",
"quota_include_external_storage": false,
"maintenance": false,
"appcodechecker": false,
"trashbin_retention_obligation": "1,1",
"enabledPreviewProviders": [
"OC\\Preview\\PNG",
"OC\\Preview\\JPEG",
"OC\\Preview\\GIF",
"OC\\Preview\\BMP",
"OC\\Preview\\XBitmap",
"OC\\Preview\\MP3",
"OC\\Preview\\TXT",
"OC\\Preview\\DCM",
"OC\\Preview\\MarkDown",
"OC\\Preview\\Illustrator",
"OC\\Preview\\Postscript",
"OC\\Preview\\Photoshop",
"OC\\Preview\\TIFF"
"mail_smtpmode": "smtp",
"mail_smtphost": "smtp.sendgrid.net",
"mail_smtpauth": 1,
"mail_smtpauthtype": "LOGIN",
"mail_from_address": "ted.strauss",
"mail_domain": "mcgill.ca",
"mail_smtpport": "465",
"mail_smtpsecure": "ssl",
"integrity.excluded.files": [
"core\/css\/header.css",
"core\/img\/favicon.ico",
"core\/img\/background.jpg",
"core\/img\/logo.svg",
"core\/img\/logo-icon.svg",
"core\/img\/favicon.svg",
"updater\/vendor\/autoload.php",
"updater\/vendor\/composer\/autoload_real.php",
"updater\/vendor\/composer\/autoload_static.php"
"debug": true,
"theme": ""
Enabled:
- activity: 2.4.1
- audioplayer: 2.5.0
- checksum: 0.3.5
- comments: 0.3.0
- configreport: 0.1.1
- customgroups: 0.4.0
- dav: 0.3.2
- diagnostics: 0.1.4
- external: true
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_clipboard: 0.7.1
- files_external: 0.7.1
- files_external_ftp: 0.2.0
- files_pdfviewer: 0.10.0
- files_sharing: 0.10.1
- files_texteditor: 2.3.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- gallery: 16.1.1
- impersonate: 0.4.0
- market: 0.2.5
- notifications: 0.3.2
- systemtags: 0.3.0
- templateeditor: 0.3
- user_ldap: 0.10.0
Disabled:
- encryption
- firstrunwizard
- provisioning_api
- theme-example
- updatenotification
- user_external
yes, Local.
No
Are you using an external user-backend, if yes which one:
yes, LDAP
Private
Multiple
Multiple
