External Storage Save in session does not prompt for user login
Greetings,
Fresh install - new admin. Attempted to set up external storage accessed via SMB/CIFS. Wanted per user authentication so selected Login Credentials save in session. When A user attempts to access the external storage a “Storage not available” error is returned. If I add a username and password pair to the configuration in the admin panel it works fine - but then all my users are in the same login which is not what I require.
Shouldn’t they be prompted for a login/password pair for the session? Or am i missing something I am not getting from checking the admin manual?
1.Create external storage accessed via SMB/CIFS
2.Select Log-in credentials save in session
3.user attempts to access the external storage - fails
4.Share and enjoy
Expected user to be prompted for login and password
No credential prompt - external storage unavailable
Operating system: Debian Jessie
Web server:2.4.10 (Debian)
Database: MySQL 5.5.54-0+deb8u1
PHP version:5.6.30-0+deb8u1
ownCloud version (see ownCloud admin page):
Updated from an older ownCloud or fresh install:Fresh install
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): External Storage
Exception: {"Exception":"OCP\\Files\\StorageNotAvailableException","Message":"Invalid login","Code":0,"Trace":"#0 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(279): OCA\\Files_External\\Lib\\Storage\\SMB->getFileInfo('')\n#1 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(436): OCA\\Files_External\\Lib\\Storage\\SMB->stat('')\n#2 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(616): OC\\Files\\Storage\\Common->test()\n#3 \/var\/www\/owncloud\/apps\/files_external\/lib\/config.php(231): OCA\\Files_External\\Lib\\Storage\\SMB->test(false, false)\n#4 \/var\/www\/owncloud\/apps\/files_external\/lib\/Controller\/StoragesController.php(255): OC_Mount_Config::getBackendStatus('\\\\OCA\\\\Files_Exte...', Array, false, false)\n#5 \/var\/www\/owncloud\/apps\/files_external\/lib\/Controller\/UserGlobalStoragesController.php(119): OCA\\Files_External\\Controller\\StoragesController->updateStorageStatus(Object(OCA\\Files_External\\Lib\\StorageConfig), false)\n#6 [internal function]: OCA\\Files_External\\Controller\\UserGlobalStoragesController->show(1, false)\n#7 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(159): call_user_func_array(Array, Array)\n#8 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\Files_External\\Controller\\UserGlobalStoragesController), 'show')\n#9 \/var\/www\/owncloud\/lib\/private\/AppFramework\/App.php(99): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\Files_External\\Controller\\UserGlobalStoragesController), 'show')\n#10 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(46): OC\\AppFramework\\App::main('UserGlobalStora...', 'show', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#11 [internal function]: OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#12 \/var\/www\/owncloud\/lib\/private\/Route\/Router.php(280): call_user_func(Object(OC\\AppFramework\\Routing\\RouteActionHandler), Array)\n#13 \/var\/www\/owncloud\/lib\/base.php(891): OC\\Route\\Router->match('\/apps\/files_ext...')\n#14 \/var\/www\/owncloud\/index.php(54): OC::handleRequest()\n#15 {main}","File":"\/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php","Line":172}
Integrity status for oC9+
