Tried to search for the possible fix for this, but cant fin one. Can any one help me please? Thank you in advance.
Integrity status for oC9+
Technical information
them.
Results
- core
- EXTRA_FILE
- core/doc/admin/enterprise_files_drop/files_drop.html
- core/doc/admin/enterprise_files_drop/index.html
- core/doc/admin/installation/hiawatha_configuration.html
- core/doc/admin/installation/macos_installation.html
- core/doc/admin/installation/nginx_configuration.html
- core/doc/admin/installation/ucs_installation.html
- core/doc/admin/installation/yaws_configuration.html
- core/doc/admin/_images/app-sharepoint-enable.png
- core/doc/admin/_images/ldaphome-2.png
- core/doc/admin/_images/ldaphome-3.png
- core/doc/admin/_images/sharepoint-drive-config.png
- core/doc/admin/_images/ldaphome-1.png
- core/doc/admin/_images/ldaphome-4.png
- core/doc/admin/_images/ldaphome-5.png
- core/doc/admin/_images/ldaphome-6.png
- core/doc/admin/_images/logging-3.png
- core/doc/admin/_images/ucsint.png
- core/doc/admin/_images/ucsint1.png
- core/doc/admin/_images/ucsint2.png
- core/doc/admin/_sources/enterprise_files_drop/files_drop.txt
- core/doc/admin/_sources/enterprise_files_drop/index.txt
- core/doc/admin/_sources/installation/hiawatha_configuration.txt
- core/doc/admin/_sources/installation/macos_installation.txt
- core/doc/admin/_sources/installation/nginx_configuration.txt
- core/doc/admin/_sources/installation/ucs_installation.txt
- core/doc/admin/_sources/installation/yaws_configuration.txt
- core/doc/user/_images/calendar_create_event_repeat.png
- core/doc/user/_images/calendar_create_event_share.png
- core/doc/user/_images/calendar_edit_event.png
- core/doc/user/_images/calendar_export.png
- core/doc/user/_images/calendar_import.png
- core/doc/user/_images/documents_personal_settings.png
- core/doc/user/_images/email_address_personal_settings.png
- core/doc/user/_images/event_export.png
- core/doc/user/_images/full_name.png
- core/doc/user/_images/language_personal_settings.png
- core/doc/user/_images/notifications_personal_settings.png
- core/doc/user/_images/oc_documents_col_edit.png
- core/doc/user/_images/oc_documents_share.png
- core/doc/user/_images/password_change.png
- core/doc/user/_images/profile_picture_personal_settings.png
- core/doc/user/_images/sharepoint-drive-config-user.png
- core/doc/user/_images/usage_indicator.png
- dav
- EXTRA_FILE
- lib/carddav/card.php
- files_external
- EXTRA_FILE
- 3rdparty/icewind/streams/tests/bootstrap.php
- 3rdparty/icewind/streams/tests/CallbackWrapper.php
- 3rdparty/icewind/streams/tests/IteratorDirectory.php
- 3rdparty/icewind/streams/tests/NullWrapper.php
- 3rdparty/icewind/streams/tests/phpunit.xml
- 3rdparty/icewind/streams/tests/Wrapper.php
- lib/failedcache.php
- lib/failedstorage.php
- files_antivirus
- EXTRA_FILE
- CONTRIBUTING.md
- README.md
- l10n/.gitkeep
Raw output
Array
[core] => Array
[EXTRA_FILE] => Array
[core/doc/admin/enterprise_files_drop/files_drop.html] => Array
[expected] =>
[current] => 148edd7c3802c370d2e080c9a8b2af2639252c153fd7f1cca4473942a6a1e7e90048a26bc3e909017712265335944130755c4b179165488b5b7ac3f10b6644ff
[core/doc/admin/enterprise_files_drop/index.html] => Array
[expected] =>
[current] => 6fcf75d9c971a97be05afbeb195125ecb6314ff05e12e8b1af3abd264cebe797569657df01ace14a047dcf354523843096e8758c38322028890da230244391df
[core/doc/admin/installation/hiawatha_configuration.html] => Array
[expected] =>
[current] => b5d0884d8d1be625123eca5890d3f1b1597b88f259b59a7b6285932a9ac39bd829ce91019b1876f24dbafd5674233d7c9340a59ff8b7971e13f4199c14d1031b
[core/doc/admin/installation/macos_installation.html] => Array
[expected] =>
[current] => 9763e10f4663f9514251104f9cb4c83f4a8d9cbf7b7fe69295445b70524293a3603e7ae94046346d805c01c7726b5cf49c1c53b661d86970e2773cfbb2dd6647
[core/doc/admin/installation/nginx_configuration.html] => Array
[expected] =>
[current] => c3e91b5966c8ec04b765db92db1d14f8f16964e583c1c9d7f94dfb83c8b29b650af0c0c2f0298dbc7348e37ae84544861f34c28213f8eda6c65e556d260333ba
[core/doc/admin/installation/ucs_installation.html] => Array
[expected] =>
[current] => c808488bc2440958cb3357a80bfbd3c24e2f3c0d7623342f55ea4108d168841758a6a79719e71c9e9a385612cecdf0904ae42eae059b154fd6484cb8be8c33fa
[core/doc/admin/installation/yaws_configuration.html] => Array
[expected] =>
[current] => d4ecbe9b3969a07a8b9cf7dd81839c9e9de65274b0182a962b09edf796a1c6833e4358ba7295a741c70a957dee62ab7cb43775f9529a8415ee0311fc2e1f0550
[core/doc/admin/_images/app-sharepoint-enable.png] => Array
[expected] =>
[current] => d0150e8d7104374f2fd17e97ae4652c8096b62d88b262852cf9af8b6d143058cac1d5b622026b057d9ae20bf6036ebd010810b5d7f0d9a61ac5ef0435382a1bc
[core/doc/admin/_images/ldaphome-2.png] => Array
[expected] =>
[current] => 42183bb85358786dafd8d9597dade50cfb82223bea5fa2125501e335d22dcd4480aca74034e6380cf082ebffaeda2cdea593ac9458398f405645e6a08d683707
[core/doc/admin/_images/ldaphome-3.png] => Array
[expected] =>
[current] => fe6f979be6d2488e844b4c30177c5cda438d0f77f567cadf1c28267d03c3f3f5ffa5f7f68c5911190eaca7b8ce268ce1494e3c661dca1a9e8208eb64b51d12d8
[core/doc/admin/_images/sharepoint-drive-config.png] => Array
[expected] =>
[current] => e9d44dc6f3b1eb5a23c29c0b08d3c45ed87600e07a693389f260ca2e376aee6a0448468fca5c9d14018815ae1eba10a4f1cd35576cc2f455d17b60e2450ef407
[core/doc/admin/_images/ldaphome-1.png] => Array
[expected] =>
[current] => c25b92135000d83d51a7dcb3eb13f07ede3ea44ad745772724c470a4c7a35a3b248f99c4666b8a5b44686e653a514be6d1ed7565d733b893fde8a4fc42b7ede1
[core/doc/admin/_images/ldaphome-4.png] => Array
[expected] =>
[current] => 6ee8adae8642694fa42d3a957500b4986c8661183cd27f1516e725eda564d40936fb64a5944e01d66f65bbf461a9a8bf4ebd566e2361d0ad2a58b65179465169
[core/doc/admin/_images/ldaphome-5.png] => Array
[expected] =>
[current] => 0c2849dd95d716d8e367c4c669086c0ba0d411ea925ccce4f90c145cdf7017fbd428b9b5eb5c73711546d5ad5baa439fab878b0a8ba2805d757c340cd8aa27f6
[core/doc/admin/_images/ldaphome-6.png] => Array
[expected] =>
[current] => 67c266a60f8244ecd71b1d2ca984127b86872fb8f2ceeafbeddf1e75c9a2b24ebafaa7284ea01e4d1f9e68207b3b515e85627c453d1030e73d20ec1819b1efc7
[core/doc/admin/_images/logging-3.png] => Array
[expected] =>
[current] => 08cf6efae2b4e9d5a7c54f56c4d9cb77e7d2db98d038baeb050c4e0012c9a89432161f718aecf01172172587437c280a0d9b6863b5ac9f3c880cc408b9ef8af1
[core/doc/admin/_images/ucsint.png] => Array
[expected] =>
[current] => 14632281c271c8b70c8c595e32d8a63ed6ac37bd5f78a617e16ac6352f0b0c1055f6c7fd240892255c548a68c8d0748a6a1f973e426f18e07e5f8b10131ac3cd
[core/doc/admin/_images/ucsint1.png] => Array
[expected] =>
[current] => 5afc72a729993f9b511a324afaf447d95bec368289f57b3be29559347f9f62c7b40b4386c044973eb568f1a99903cde5e94e9390c0d9d986beff42eb66a2cca8
[core/doc/admin/_images/ucsint2.png] => Array
[expected] =>
[current] => 81f9ede0250a63266252ab692cd1ec828d846cbfb4cf445b77057327449555687ff52a24395e18cc24af45126617c57c97a90178fe7f74525194163284c093c3
[core/doc/admin/_sources/enterprise_files_drop/files_drop.txt] => Array
[expected] =>
[current] => dc38542768119e6836ceacbeabcad403a7f947ecdae5f3c8e3c9d9123e6c767ef3fe082877a3e9d08eed08872af9e72e6fe924940c23b035393783187d6f717c
[core/doc/admin/_sources/enterprise_files_drop/index.txt] => Array
[expected] =>
[current] => d09dd1c22415ce32f31d8c0cef83967fd195dd9d38567c23dcb471f816edf7ecac56b31a736ca07a8fd9df82b32d7cd25575f5ab83ac4b8023ea4fa6b048837c
[core/doc/admin/_sources/installation/hiawatha_configuration.txt] => Array
[expected] =>
[current] => 9bfdd0bbbcf9fe67ac3461391a100f6865cd0589993733a6054c7bfa2538f41991f05a9732f84394dcd41c5f72e399ec0776c15342482fa1f943bc430dda5e77
[core/doc/admin/_sources/installation/macos_installation.txt] => Array
[expected] =>
[current] => ed4ae1b1ad79d9af4c22ba637d8c490006ecf38a1370d99b22a6d1f8ed0747350458984486df94de304fb12c825512aede3174a1f406c1c00b781dc4cb3d04e6
[core/doc/admin/_sources/installation/nginx_configuration.txt] => Array
[expected] =>
[current] => 3df53110571e8f8610b5c962fbb8587a8311c999f1f63254f60bfb83a95a58b9db7f262343cbc5005cbea01d55c6fa39182af52f40c66c94220537a7671ec28c
[core/doc/admin/_sources/installation/ucs_installation.txt] => Array
[expected] =>
[current] => cff91efec5bda3f5c6594f0ab4c5876bb7b6b0f66513f795df7d9cffc2aa1d469d8cdf2765d6327d0c02d4959dde1e7c7840f01d1bdc5b17033dc5e1abb664ed
[core/doc/admin/_sources/installation/yaws_configuration.txt] => Array
[expected] =>
[current] => d4b693ce8997ca9b5da58448ceccb094cb0cfaf1343f01f1a92b992e22f1b8a83bf541a2d88c093a4b3c2f46485083042854317db531c0b090602416bb7e4d60
[core/doc/user/_images/calendar_create_event_repeat.png] => Array
[expected] =>
[current] => 53939e0e3eef1b3763cbd81cac8fc80da72e2628f5b1ee360f3e36374239d5606a3ba1698d8ea1672f4df1bcb6b5c342df6ad82e097256c1bbc7b24704733fea
[core/doc/user/_images/calendar_create_event_share.png] => Array
[expected] =>
[current] => a4f8f8b549856044bdce8df9c1f4f57e6bc28aeaee3dfcacdfe4083f36c14f5bd653c26f88c2210d315e607161011382e0c5edcb369e47fc30009cc9ae608731
[core/doc/user/_images/calendar_edit_event.png] => Array
[expected] =>
[current] => 796983312c658d6b19fea3ead447a208a23b90ec0a64fea056170bcbb10aed586bde33586062d548fe35705da26436d801e0881521e0728c6349d87ee1ac030d
[core/doc/user/_images/calendar_export.png] => Array
[expected] =>
[current] => 41845ccd72c00468c7a118083a0917055c30b1763747b1bbe8c19f6bc50a56efe17439bd6339000feb1d979fcc82cf8f9cfbac5362e3a06e7f69f7041cd7e73b
[core/doc/user/_images/calendar_import.png] => Array
[expected] =>
[current] => 377447159556a54a11ec3953f3c5ce0dd7ebfdf5bd2c5920421a249505cf4ebceae97bda51b0fac7ef2051d280e918a605ad9f9c3674d3e91d2851f282cc69c5
[core/doc/user/_images/documents_personal_settings.png] => Array
[expected] =>
[current] => a70d566d08d8cacc38fd13cf7cbad7e59050eb86f42efb675c3760bd469cb171461f16c47a9cadaf33893b10bbf919204616601a00edad4bc1fdb63cf2336aaa
[core/doc/user/_images/email_address_personal_settings.png] => Array
[expected] =>
[current] => 506df578c8d84efb3352004f862cf699f309a90bff0175cb4fe8c085d255484fa31e768b07e44fa8e8b80691b0f6d48b0c115d3a7b84a0db89bc7cb03bbd5809
[core/doc/user/_images/event_export.png] => Array
[expected] =>
[current] => f1db57d698b6433c873cab62e1ed416043c334dd23c71b40402bb0f838186939ad552371d49e5c844600cdbbbb80c1036c278eea5832f0f2c7eb9e8a3a5e4916
[core/doc/user/_images/full_name.png] => Array
[expected] =>
[current] => 6e0564210919f31c3697aa3849734696c1cbeed0875ae234d1319f449a92ef35a5cf8486bea7a1edabbe574a319b7f7fd182d28ec3fbf9bdbe9109fb6bbbacb6
[core/doc/user/_images/language_personal_settings.png] => Array
[expected] =>
[current] => 4532e2cda43c738d94ee8f3cd3645f7677283dcffa21d41af341d4f8c5d3a2ad3dc25ba521b052a57506c7a188106cd10e480cd9e213a419b4fdfd29a6552a97
[core/doc/user/_images/notifications_personal_settings.png] => Array
[expected] =>
[current] => 271ca098b7ec2864e97187ab52a54e4c7b53c7fb81b2927c153f03d4a377516abddd902aa95de58a579fd24ae975d8e064e89935728efa9e25ab4df289f9da93
[core/doc/user/_images/oc_documents_col_edit.png] => Array
[expected] =>
[current] => 702e9fcc1172e250fa8876a33f99c958816c27bdd7bae7a384d1689913a04fa061f3ae9d33298201544110040d369ec453723bd084e3e03e25419d833194dc3e
[core/doc/user/_images/oc_documents_share.png] => Array
[expected] =>
[current] => a09aa27abd88241f09200021450058b5d4eaca8afe8e621b4b83dc18a1d251039667a7cf8ce594eda5fda5b4015d2732609b6ed13ce5eb8b3e78e2fa4231c821
[core/doc/user/_images/password_change.png] => Array
[expected] =>
[current] => 2bfa22ebc1374ad997adc72784499fd9636b19f3732a33e8bf5b744a62a70d8064f27638fbae07bf39f10090dac753dc45bf9c6ebede268aaae7da2b5504016d
[core/doc/user/_images/profile_picture_personal_settings.png] => Array
[expected] =>
[current] => 8182e81db32e735b5910e450ecedeb0c6ac3a97dc40f1162721d68603120be0d7484606d641986fd65957d605201696eb063b4a2c37a238eb005cd2f6f19d3ce
[core/doc/user/_images/sharepoint-drive-config-user.png] => Array
[expected] =>
[current] => c199c045e2e0c826c288e788f353b2c340417fd762fbe3fc7c821f23a3572299e68f8b8d9eb7cd9a425c6c1072fdc55ed23a1a20f540d3f8479d1c150df6e4ba
[core/doc/user/_images/usage_indicator.png] => Array
[expected] =>
[current] => 33cafa9b6bfd4e0ecfe488e41de6c69004199dbc202be3844e7dff49006a4a3107dcfb81c9360b786bdc816f31939497901ae8b14f8fe345eeef80bdc02e131b
[dav] => Array
[lib/carddav/card.php] => Array
[expected] =>
[current] => 95cfae7278021c69c86b46ced431a48a442a7435ca3faa8a452ae534a3c45b65c64233a304a8c391f0e754a33abb7efe2cfa02545dde4a9cfe25c6300deb067a
[files_external] => Array
[3rdparty/icewind/streams/tests/bootstrap.php] => Array
[expected] =>
[current] => 865e301e6677b7f6a798fd478daedb55e90de14c4e5aaeeb934f2f5312e804495175dd314157d9c2a1085d4e2237ab707e8df7065cbfb7b448c5b9cfac45e8c3
[3rdparty/icewind/streams/tests/CallbackWrapper.php] => Array
[expected] =>
[current] => 31fb75edf39494f49662e21d914cef258efe88ba91c938e397f3f02bdf8029b63fcf9a01f4592858bb532e78f2719a7289847c761fbb703c7fee743e59a5588d
[3rdparty/icewind/streams/tests/IteratorDirectory.php] => Array
[expected] =>
[current] => c5697bbc67ed45705387fd4ec8c0e3f065191521f6fdb8adae13b9bc342dfa179d0878b2788aa72e78c21302f71f1e267b10e84096ba8b530793bf44f2b732b1
[3rdparty/icewind/streams/tests/NullWrapper.php] => Array
[expected] =>
[current] => ce6ce866bd37cdf140e6bfa283ba5be3646f4e7de648df7f15b95acc262f4ab7977cfbc73c9c0037cffe6be3395a89824b0fb5f684df8babf6c6c57ba86d8eb4
[3rdparty/icewind/streams/tests/phpunit.xml] => Array
[expected] =>
[current] => ae8c0fe7d1e095867ee4067d538847efb6477c44ddeef3551bd4fb0224e6749a454ba5989aae3738eb828c784b919b8faa92547285156a5727db1ce64366014b
[3rdparty/icewind/streams/tests/Wrapper.php] => Array
[expected] =>
[current] => 20f55868616decd2ff3162c4417e0610ddfb9f036b14d8bb84aa3d2f282a2c587a990333b048579f8c609dd16c77caeb9cf7b6c3e8ea223d8757783ea2fd0d67
[lib/failedcache.php] => Array
[expected] =>
[current] => fa82306257fd53ec440f52c49b2905f0e716a83afb538958f123ba42db936027099372101d68089368ea751f4f125a4827efa63789a1937ee5d8f6fd28a7f320
[lib/failedstorage.php] => Array
[expected] =>
[current] => 7ab1651b7edc83342545693bc4692241c959c526b37521c3c7fc2d6cb18e06ab41de972ce9144f2862a6219ff11a680a6600090c342e0f379ebc7f57a30176eb
[files_antivirus] => Array
[CONTRIBUTING.md] => Array
[expected] =>
[current] => 0de5eddd29b6be1a62c71bf217edf2c5b163916842f9976326d5254e14853fc138692ede064994a934cc911b0cd42a502db20e7be0f867af9a4c631a61ace4dc
[README.md] => Array
[expected] =>
[current] => d197f4b4e0a845261162fdc8ad5a500e579c68c9306471558da14eb3474b70889772fd88fea1161be341421c4dba3bbc63c5e85a8378b38a75d76dbdb1e3264a
[l10n/.gitkeep] => Array
[expected] =>
[current] => cf83e1357eefb8bdf1542850d66d8007d620e4050b5715dc83f4a921d36ce9ce47d0d13c5d85f2b0ff8318d2877eec2f63b931bd47417a81a538327af927da3e
