File shoud be transfered from the client to the server
file is not transfered
Don’t know, how to reproduce it or if it is reproducable.
- Created a file (here with a kyrillic name)
- run client from command line (owncloudcmd)
This happens not with all files, but with some…
Operating system: opensuse Tumbleweed
Web server: Apache 2.4.49
Database: mariadb 10.6.4
PHP version: 7.4.24
ownCloud version: 10.5.0
none
Client version: 2.9.0
OS language:
LANG=
LC_CTYPE=de_DE
LC_NUMERIC=“POSIX”
LC_TIME=“POSIX”
LC_COLLATE=C
LC_MONETARY=“POSIX”
LC_MESSAGES=“POSIX”
LC_PAPER=“POSIX”
LC_NAME=“POSIX”
LC_ADDRESS=“POSIX”
LC_TELEPHONE=“POSIX”
LC_MEASUREMENT=“POSIX”
LC_IDENTIFICATION=“POSIX”
LC_ALL=
command line
distro (software.opensuse.org)
Installation path of client:
/usr/bin/owncloudcmd
- Client logfile:
- Output of “/usr/bin/owncloudcmd --logdebug --max-sync-retries 10 --trust --non-interactive”
10-06 09:01:21:217 [ info sync.discovery ]: Processing “service/software/Face/ifc/ifc_doc/faq/ru/Ð^(92)идеоз�_пиÑ^(81)Ñ^(8C)Ñ^(8D)кÑ^(80)�_н�__и_Ñ^(81)нимки_Ñ^(8D)кÑ^(80)�_н�.pdf.NEW” | valid: false/true/false | mtime: 0/1633440119/0 | size: 0/868434/0 | etag: “”//"" | checksum: “”//"" | perm: “”//"" | fileid: “”//"" | inode: 0/381635/ | type: CSyncEnums::ItemTypeSkip/CSyncEnums::ItemTypeFile/CSyncEnums::ItemTypeFile
10-06 09:01:21:217 [ debug sync.database.sql ] [ OCC::SqlQuery::bindValue ]: SQL bind 1 381635
10-06 09:01:21:217 [ debug sync.database.sql ] [ OCC::SqlQuery::exec ]: SQL exec “SELECT path, inode, modtime, type, md5, fileid, remotePerm, filesize, ignoredChildrenRemote, contentchecksumtype.name || ‘:’ || contentChecksum FROM metadata LEFT JOIN checksumtype as contentchecksumtype ON metadata.contentChecksumTypeId == contentchecksumtype.id WHERE inode=?1”
10-06 09:01:21:217 [ info sync.discovery ]: Not a move, no item in db with inode 381635
- Web server error log:
- nothing in the error logs
- Server logfile: ownCloud log (data/owncloud.log):
- nothing in the logs, just auth messages
Regards
Daniel
