- Migrate data directory from external drive back to local HD
2.Try to upload/download any file type
User should be able to Upload or Download files
Forbidden error
Ubuntu 16.04
Apache2
Mysql
10.0.8
installed fresh
CLI - owncloud repository
This returns nothing - 404 error
"system": {
"updatechecker": false,
"instanceid": "oc9v0jduwrsw",
"trusted_domains": [
"172.0.0.1",
"xx.xx.xxx.xx",
"172.20.224.19"
"datadirectory": "/var/www/satclouddata/data",
"overwrite.cli.url": "http://xx.xx.xx.xx/owncloud",
"dbtype": "mysql",
"version": "10.0.8.5",
"dbname": "satcloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"mail_smtpmode": "php",
"updater.secret": "***REMOVED SENSITIVE VALUE***"
Are you using external storage, if yes which one:
no
Firefox
Mac OS X
N/A
{"reqId":"09df7c9c-4367-4b62-8fda-325e3db5a50e","level":3,"time":"2018-12-28T04:17:07+00:00","remoteAddr":"172.20.224.55","user":"jsmith","app":"no app in context","method":"GET","url":"\/owncloud\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","message":"User backend OC\\User\\Database is returning home: \/var\/www\/satclouddata\/data\/jsmith for user: jsmith which differs from existing value: \/mnt\/satcloudmain\/satclouddata\/data\/jsmith"}
{"reqId":"E2yw4TGqUOIxEyaBOoW9","level":3,"time":"2018-12-28T04:20:07+00:00","remoteAddr":"76.94.218.160","user":"satcloudadmin","app":"no app in context","method":"GET","url":"\/owncloud\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","message":"User backend OC\\User\\Database is returning home: \/var\/www\/satclouddata\/data\/satcloudadmin for user: satcloudadmin which differs from existing value: \/mnt\/satcloudmain\/satclouddata\/data\/satcloudadmin"}
{"reqId":"c8abfddb-fa45-4f8d-83cd-7039ecd529a3","level":3,"time":"2018-12-28T04:20:07+00:00","remoteAddr":"50.239.2.142","user":"securityservers","app":"no app in context","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/securityservers\/","message":"User backend OC\\User\\Database is returning home: \/var\/www\/satclouddata\/data\/securityservers for user: securityservers which differs from existing value: \/mnt\/satcloudmain\/satclouddata\/data\/securityservers"}
{"reqId":"2b8f6c30-33ac-4025-9d9c-8336651a9818","level":3,"time":"2018-12-28T04:20:13+00:00","remoteAddr":"73.169.205.27","user":"lbooth@xxx.com","app":"no app in context","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/lbooth@xxx.com\/","message":"User backend OC\\User\\Database is returning home: \/var\/www\/satclouddata\/data\/lbooth@xxx.com for user: lbooth@xxx.com which differs from existing value: \/mnt\/satcloudmain\/satclouddata\/data\/lbooth@xxx.com"}
{"reqId":"7a748e59-bee6-44ac-a6b3-152e7022690a","level":3,"time":"2018-12-28T04:21:21+00:00","remoteAddr":"76.94.218.160","user":"jsmith","app":"no app in context","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/jsmith\/","message":"User backend OC\\User\\Database is returning home: \/var\/www\/satclouddata\/data\/jsmith for user: jsmith which differs from existing value: \/mnt\/satcloudmain\/satclouddata\/data\/jsmith"}
N/A
It looks like the database tables are trying to connect everything to the old drives that aren’t there any longer. How do I tell OwnCloud to use the config.php data location globally for all of the users?
