I know that this is likely pilot error here, but I am trying to make the new Object Storage plugin work with ownCloud 10.0.9. I am very likely NOT doing something correctly. But here is what I have done.
- Configured OC on an OpenStack vm. Seems to work great with local storage.
- I downloaded and copied to “apps” the new “files_primary_s3” app from the marketplace to my server.
2a. I enable the plugin via the UI. - I configure in a new objectstore stanza in my config.php file following the instructions found on github (complete file below.)
- I reboot everything.
- The web UI does not ever respond after this. Locks up.
- No useful messages in owncloud.log
- If I take out the objectstore stanza, reboot, then all seems well again.
I know I am totally missing something here. Docs are scarce.
Any help appreciated.
my OC magically starts using my Rados bucket on Ceph.
UI Locks up.
SLE 15
Apache 2.4.33
MariaDB
10.0.9
Fresh
OC Website download tarball
<?php
$CONFIG = array (
'instanceid' => 'ocf8r04aht11',
'passwordsalt' => xxxxxx,
'secret' => yyyyyy,
'trusted_domains' =>
array (
0 => 'ww.xx.yy.zz',
'datadirectory' => '/srv/www/htdocs/owncloud/data',
'overwrite.cli.url' => 'http:/ww.xx.yy.zz/owncloud',
'dbtype' => 'mysql',
'version' => '10.0.9.5',
'dbname' => 'ocdb',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'mysql.utf8mb4' => true,
'dbuser' => 'oc_admin',
'dbpassword' => 'yyyyyyy',
'logtimezone' => 'UTC',
'installed' => true,
'objectstore' => [
'class' => 'OCA\Files_Primary_S3\S3Storage',
'arguments' => [
// replace with your bucket
'bucket' => 'ownclouddemo',
'autocreate' => true,
// uncomment to enable server side encryption
//'serversideencryption' => 'AES256',
'options' => [
// version and region are required
'version' => '2006-03-01',
'region' => 'us-east-1',
'credentials' => [
// replace key and secret with your credentials
'key' => 'xxxxxx',
'secret' => 'yyyyyy',
'use_path_style_endpoint' => true,
'endpoint' => 'oururl:80/',
‘admin’ -> ‘Generate Config Report’ -> ‘Download ownCloud config report’
**List of activated apps:**
Well trying too.....
no
no
SELECT * FROM oc_appconfig
WHERE appid
= ‘user_ldap’;
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
c) …
