Hİ :
How to authorize groups with owncloud ?
Can you elaborate a little more what you’re trying to achieve?
If you have a user group for example in your Active Directory domain that you want to be able to log in to your ownCloud installation, you will need the LDAP integration app.
You can find documentation on how to set this up here:
https://doc.owncloud.com/server/admin_manual/configuration/user/user_auth_ldap.html
Thank you
