Help server error owncloud not accesible
Please help me on this error
owncloud.log tell
{“reqId”:“7757a47a8ff5767d2f998ec723ec470b”,“remoteAddr”:“93.34.134.128”,“app”:“index”,“message”:“Exception: {"Message":"An exception occurred while executing ‘PRAGMA journal_mode = WAL’:\n\nSQLSTATE[HY000]: General error: 26 file is encrypted or is not a database","Code":0,"Trace":"#0 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php(973): OC\\DB\\Connection->connect()\n#1 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/db\/connection.php(132): Doctrine\\DBAL\\Connection->executeUpdate(‘PRAGMA read_unc…’, Array, Array)\n#2 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php(621): OC\\DB\\Connection->executeUpdate(‘PRAGMA read_unc…’)\n#3 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/db\/connection.php(66): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#4 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrine\\DBAL\\Driver\\PDOSqlite\\Driver), Object(Doctrine\\DBAL\\Configuration), Object(Doctrine\\Common\\EventManager))\n#5 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/db\/connectionfactory.php(107): Doctrine\\DBAL\\DriverManager::getConnection(Array, Object(Doctrine\\DBAL\\Configuration), Object(Doctrine\\Common\\EventManager))\n#6 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/server.php(243): OC\\DB\\ConnectionFactory->getConnection(‘sqlite3’, Array)\n#7 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php(112): OC\\Server->OC\\{closure}(Object(OC\\Server))\n#8 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/appframework\/utility\/simplecontainer.php(91): Pimple\\Container->offsetGet(‘DatabaseConnect…’)\n#9 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/server.php(540): OC\\AppFramework\\Utility\\SimpleContainer->query(‘DatabaseConnect…’)\n#10 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/db.php(33): OC\\Server->getDatabaseConnection()\n#11 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/server.php(178): OC_DB::getConnection()\n#12 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php(112): OC\\Server->OC\\{closure}(Object(OC\\Server))\n#13 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/appframework\/utility\/simplecontainer.php(91): Pimple\\Container->offsetGet(‘AppConfig’)\n#14 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/server.php(488): OC\\AppFramework\\Utility\\SimpleContainer->query(‘AppConfig’)\n#15 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/app.php(218): OC\\Server->getAppConfig()\n#16 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/app.php(71): OC_App::getEnabledApps()\n#17 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/base.php(542): OC_App::loadApps(Array)\n#18 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/base.php(1026): OC::init()\n#19 \/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/index.php(34): require_once(‘\/web\/htdocs\/www…’)\n#20 {main}","File":"\/web\/htdocs\/www.gb-consulting.it\/home\/fabi\/cloudfabi\/lib\/private\/db\/connection.php","Line":33}”,“level”:4,“time”:“2017-05-21T08:41:03+00:00”}
i don’t know how solve this problem
what was changed in your environment to get to this state?
Nothing.
I had only create a new folder for photos and share it with link, and all was ok.
My sister look the photos and then she read this message.
Then it reimain on this way. :persevere:
As you’re running SQLite some general advises:
  1. Revert to a previous working backup
  2. Install MySQL / PostgreSQL
  3. Migrate your database to MySQL / PostgreSQL: ownCloud Documentation Overview
SQLite is nothing what you should run on a productive system, especially if using more then one single user.
