Please help us by providing the following info.
Before posting please also check the pinned "Known issues" threads and
make sure that you're running the latest available version for your oC
release: https://owncloud.org/changelog/
1. Reboot Owncloud server once or twice a day
2. Memory utilization is normal to start with
3. After a few hours mysqld is using a huge amount of memory
Memory utilization should remain normal - no reboots necessary
Daily reboot required.
OS: Centos 7
Web server: Nginx
Database: Mysql / Mariadb
PHP version: 2.4.0
ownCloud version (see ownCloud admin page): 9.1.1 stable
Integrity status for oC9+
paste the results here.
ps aux --sort=-%mem | awk 'NR<=10{print $0}'
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
mysql
14112 6.4 2.3 1761684 189996 ? Sl 07:25 1:41
/usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql
--plugin-dir=/usr/lib64/mysql/plugin
--log-error=/var/log/mariadb/mariadb.log
--pid-file=/var/run/mariadb/mariadb.pid
--socket=/var/lib/mysql/mysql.sock
This is a virtual server and I have tried increasing memory from 8gb to 16 gb but the issue still occurs.
Solved by RealRancor in post #2created33mlast reply17m2replies9views2users3linksRealRancor17mHi,
issues like that should be always reported directly to ://github.com/owncloud/core/issues1
Thanks.Solution
Thanks RealRancor
Correct me if I am wrong but reporting issues to GitHub would imply that there is something wrong with the code.
However in this case I am sure that the issue is more likely to be with my configuration, particularly with mysql. Hence a forum would be the better platform.
Cheers
