How add hard drive external local
How can i add my external hard drive to my Owncloud 10.0.7?
I find and modify this:
'files_external_allow_create_new_local' => 'true',
so now I have the local option, but when I put the path "/ dev / sda1" it does not work, nothing is displayed, my SD card is not displayed too.
Have I forgotten something?
i don’t think that you can put a path like /dev/sda1 into that input box. From what i know that is a special device on linux which needs to be mounted on your filesystem first before ownCloud is able to access it.
thank you for the answer. So how can I add a hard drive that can be recognized in Owncloud? By putting it in a folder?
I think “mounting” the hard drive first would be the correct way to make the drive known to the operating system and to ownCloud.
